Steering Coupler/Rag Joint Replacement
Old Oct 20, 2022 | 05:46 AM
BOOM_FIST's Avatar
BOOM_FIST
Searched the Forum with no luck....hope someone can help.
Just got the truck back from the shop after installing a 6" Pro Comp lift and they had to replace the steering box as well. I was 50/50 on replacing the steering box myself anyway so it's all good. All new ball joints, tie rods, drag link, and pitman arm. Fresh alignment and the whole front end is nice, tight, and new. I'm really happy.
I do still have some play in the steering wheel and suspect that it's the steering coupler. Since I've replaced literally everything steering related with the exception of the steering coupler, I'd be dumb not to spend the cheap amount that the coupler costs to replace it and hope it fixes/helps the steering play.
Looking for pictures, tutorial, part number for the steering coupler for my 2004 Excursion so I can hopefully eliminate this slop in the steering wheel! Since it's not exactly easy to get to, I was hoping to see some pictures so I can tackle it soon with little down time.
Thanks for any help guys!
-Tom
Old Oct 20, 2022 | 11:02 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Take your pick
Ford
https://www.tascaparts.com/oem-parts...wtdjgtZGllc2Vs
Dorman
Amazon Amazon
Borgeson
https://www.borgeson.com/99-07-Ford-...F250-F350.html
Old Oct 20, 2022 | 12:18 PM
BOOM_FIST's Avatar
BOOM_FIST
Is the coupler not separate from the shaft? So, I take it the entire lower shaft needs to be replaced in order to replace just the coupler?
Old Oct 20, 2022 | 02:08 PM
pirate4x4_camo
One end is welded to the shaft and the Rag is riveted.
if can can fabricate just cut it off and weld a new one on.
https://www.speedwaymotors.com/shop/...4-15-574-31188
Old Oct 20, 2022 | 03:55 PM
Antonm's Avatar
Antonm
That borgeson shaft that Pirate linked above will get rid of the rag joint and replace it with a u-joint. More expensive, but its a bit of an upgrade.
Old Oct 20, 2022 | 05:41 PM
01__Excursion's Avatar
01__Excursion
More parts for me to buy?
I never looked at mine, is this a wear and tear item that will cause enough play in the steering to do something about?
Old Oct 21, 2022 | 05:25 AM
BOOM_FIST's Avatar
BOOM_FIST
Originally Posted by pirate4x4_camo
One end is welded to the shaft and the Rag is riveted. if can can fabricate just cut it off and weld a new one on.
Thanks so much for the responses and links! I have a welder and could cobble something up for sure. Good info that it's not separate from the lower steering shaft from the factory.
I've seen this discussion and it's sort of tempting to go to a solid/rigid setup to eliminate any chance of steering shaft slop, but I've determined that the rubber coupler lasts a long time and a fresh one should fix most, if not all, of the slop and still do it's job of reducing steering wheel vibration and buffering.
Originally Posted by 01__Excursion
More parts for me to buy? I never looked at mine, is this a wear and tear item that will cause enough play in the steering to do something about?
I would say it is definitely a wear and tear item that should be checked/replaced any time there is play in the steering wheel. I replace the one on my 74 E300 because of excessive play and it helped out a lot.
Old Oct 21, 2022 | 05:35 AM
BOOM_FIST's Avatar
BOOM_FIST
With all that being said, I had some time after work and before some evening plans to dig my hands through the fender well and grab the steering shaft and inspect the rubber coupler.
The rubber coupler looks pretty good and not rotted out or cracked at all. I grabbed the steering shaft, with the truck off and in park, and I could hear and visually see the steering gear box spline moving a significant amount. No doubt, the play is in the brand new steering gear box. It's a NAPA brand stock replacement that I'm fine with, but is there an "out of the box" preload adjustment that the shop may have overlooked when installing?
Either way, I have a call into the shop already and hopefully they can guide me to adjusting it or they do it themselves.....OR, they have to replace the defective steering gear box and I'll probably make a deal with them to just install a Red Head or Blue Top gear box and I'll pay the difference.
This is giving me the idea to walk the local junkyard and pull a spare steering shaft and cobble up a solid U-joint setup on the cheap instead of the $300+ Borgeson to test if it's as good/bad as some people are saying.
Old Oct 21, 2022 | 07:55 AM
Antonm's Avatar
Antonm
I have a Borgeson shaft on another vehicle (not the Excursion), it works good but its not like an "all that and a bag of chips" or anything type improvement. Rag joints work, the Borgeson shaft is a bit of an improvement. I needed to replace the steering shaft on that other truck to work with a non-stock steering box anyway, since I was having to buy a new shaft, figured why not.
Old Oct 21, 2022 | 03:25 PM
pirate4x4_camo
Before you go messing with the preload adjuster be aware the the steering input shaft is connected to a torsion spring inside the valve portion of the steering box, this torsion spring winding and unwinding puts about 1” of “slop” at the steering wheel. The steering gear is designed this way on purpose.
Check your intermediate shaft slip joint, this is an area that typically wears quicker that the rag joint.
Old Oct 21, 2022 | 11:53 PM
callforfire's Avatar
callforfire
I'm thinking it's the E series vans that use a U-joint instead of a rag joint. I only briefly looked into it.
Those appear to be pinned or cross-bolted on the shaft but never dug any further to see about adapting it as a rag joint replacement.
They are still pretty pricey but might be an option between Borgeson and rag joint.
Old Oct 23, 2022 | 11:01 AM
BOOM_FIST's Avatar
BOOM_FIST
I can only assume the “proper” way to measure play in the steering, but someone please guide me haha.
I’ll try and get a video of the steering shaft play and hopefully someone can advise on what I should do.
Old Oct 23, 2022 | 01:45 PM
pirate4x4_camo
the correct procedure is in the Factory service manual. It’s a process
Old Oct 23, 2022 | 03:01 PM
BOOM_FIST's Avatar
BOOM_FIST
Don’t know if this will work, but here’s a short clip of the play. Parked engine off. Literally using 2 fingers to move it effortlessly.
It’s really unenjoyable to drive at the moment. Feels even worse than with the old steering gear box which I suspected was wearing out because of the slop.
File Type: mov
Old Oct 25, 2022 | 10:39 PM
Jakerichards1's Avatar
Jakerichards1
Repeat. Engine off is not how to check for play in the box. Go to redhead steering gears troubleshooting guide. They have it spelled out well how to test.
you may have ball joints that are too tight. If had a regular joe mechanic install mine they would have been too tight and binding. I had to play with the position of the upper ball joint to keep it from binding when torqued.
