EFI - problems after the engine is warm
Old Nov 12, 2003 | 09:33 AM
jbolsen's Avatar
jbolsen
Fuel Problems.... Just purchased a 88 F250 with a 460. Starts and runs fine, but when the engine gets warmed up it sputters when i try to accelerate. Any ideas?
I changed the fuel filter - didn't help. Could it be the pressure regulator?
Old Nov 12, 2003 | 10:23 PM
LxMan1's Avatar
LxMan1
Hi and welcome to FTE
You can check the regulator by removing the vacuum line and see if any gas is present. If it is, then the regulator is bad.
I have seen this before when it acts like it is starving for fuel and it is actually the pick-up coil in the distributor going bad. After the truck cools for a bit, it will run fine until it gets hot again.
Jimmy
Old Nov 13, 2003 | 03:18 PM
jbolsen's Avatar
jbolsen
You were right Jimmy - I changed the distributer cap, pick-up coil, plugs, and wires and it's running great! - drinks like a camel...the ails of a 460!
Thanks a ton!
Joshua
Old Nov 13, 2003 | 05:30 PM
LxMan1's Avatar
LxMan1
Glad to help.
Jimmy
