360 stalling on downhill stops
Old Oct 16, 2022 | 06:56 PM
JackF68F250's Avatar
JackF68F250
Last year I rebuilt the Motorcraft 2100 2-bbl on my '68 360 automatic. Starts easy and runs like a top ever since EXCEPT when I come to a stop heading downhill. The engine shudders and I have to throw it into neutral to prevent stalling. Then it recovers and is fine idling on the downhill. Coming to a stop on the level or heading uphill presents no problem. Any ideas what could be the cause? Float level? Does not seem to be related to engine being cold or warm.
One thing I did not fix is the slow-return-to-idle diaphragm thingamajig part of the throttle linkage . The diaphragm seems to have failed so is not providing any damping so based on reading around the Forum I disconnected that part of the linkage as apparently not vital. Maybe it is vital after all or ?
Thanks in advance for any advice!
Old Oct 17, 2022 | 11:33 AM
FuzzFace2's Avatar
FuzzFace2
First place I would look is the float level.
Did this happen right after the carb rebuild or some time after?
Also may want to check timing and adjust the carb mixture too.
It may need that dash pot but I believe it is for smog more than anything.
If the throttle was to close fast you will the unburnt gas level go way up where if it closes slowly it only goes up a little till the throttle is closed all the way.
Dave ----
Old Oct 17, 2022 | 06:07 PM
1browski's Avatar
1browski
When I put my rebuilt 360 in my 70 f250, I switched back to my autolite 2100. I didnt have the dash pot on it. The truck wanted to almost stall every time I would let off the throttle. I would put it on before fixing parts that might not even be out of adjustment.
Old Oct 17, 2022 | 11:05 PM
JackF68F250
Thanks all for the input. I don't recall when I noticed the stalling. Probably not immediately or I would have tackled it then and there. I can pull the float bowl cover and adjust the level with the carb in the truck as I recall so I may as well check that.. In regard to the dashpot I checked t for damping action and there is nothing there so I assume the diaphragm is shot as it provides no resistance at all to throttle closing. I will need to get a new one to try it.
I also read somewhere it could be a vacuum leak involving the power brake booster, occuring only when the brakes are appllied. Interesting but that should happen on level and uphill stops too. I'll have try some fast stops going uphill to rule that out.
Old Oct 18, 2022 | 10:09 AM
FuzzFace2's Avatar
FuzzFace2
A vacuum leak raises the RPM not lower it to stall.
Also if the booster leaked just idling in park and press the pedal the RPM will change.
Also sometimes you hear a hiss when pressed.
Dave ----
Old Oct 20, 2022 | 10:58 PM
JEFFFAFA's Avatar
JEFFFAFA
I think the float level is too low. Not enough gas over the jets on down hills for gas level to be very far up the venturis. Raising or lowering the float level changes the air/fuel mixture a bit. Higher float level raises the fuel level heading up to the venturis. Thus a richer mixture. And then vice versa.
Sergio Reta
Apr 26, 2016 09:43 PM
jax72sportcustom
Sep 11, 2012 05:21 PM
Esmith215
Dec 8, 2007 04:21 AM
Project71
38
Jun 20, 2007 08:11 PM
greghoffmann
Aug 27, 2000 10:17 AM
