74- f-100 360 stalling problems
Old Dec 7, 2007 | 03:31 PM
Esmith215's Avatar
Esmith215
Truck idles very well when in park but when taking off will just stop. However if you let it get up to speed very slowly it run like normal after 40. Does anyone have any ideal what could be causing this?
Old Dec 7, 2007 | 07:40 PM
rusty7983's Avatar
rusty7983
what happens in park if you slam the pedal down? does it miss or skip?
rusty7983's Avatar
rusty7983
does it make a difference if it is hot or cold?
Old Dec 7, 2007 | 09:17 PM
Esmith215's Avatar
Esmith215
Doesn't make difference if hot or cold and doesn't miss out in park.
Old Dec 8, 2007 | 04:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The usual problem = Ford 2V carb = bad accelerator pump & check valve.
Symptoms:
Bogging down upon accelerating from a dead stop / Bucking when stepping on the gas at speed.
The fix: New accelerator pump diaphram and check valve. These can be bought separately or with the carb kit.
NOTE: When removing the old diaphragm, use caution...there's a coil spring behind it.
The acc pump diaphram & check valve are located at the front of the carb behind a plate/lever held on with 4 screws.
C4AZ-9B559-A .. Acc Pump Diaphram (Motorcraft CM-463)
C4AZ-9576-A .. Acc Pump Check Valve (Motorcraft CM-825)
D4AZ-9A586-A .. Carb Kit (Motorcraft CT-499-D)
