part identity help from engine
Old Oct 16, 2022 | 03:34 PM
Boz86's Avatar
Boz86
About 4 6 months ago I started taking the engine parts off (92 F150 5.0L) to fix the crossover tube on the fuel rail. A long hospital stay and recovery explains why this took so long.
I got a new fuel line to connect the two rails; and I'm starting to put the engine pieces back. There's one part that was mixed in with the tools and I don't recognize it. Before I put everything back and then have to pull it apart again can anyone tell me what this is?
The current status:
Last edited by Boz86; Oct 16, 2022 at 03:35 PM. Reason: Forgot to say '92 F150 5.0L
Old Oct 16, 2022 | 04:29 PM
Boz86's Avatar
Boz86
flipped it.
Old Oct 16, 2022 | 08:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Does not look like anything I have removed from a 302.
Old Oct 16, 2022 | 11:25 PM
Torky2's Avatar
Torky2
Does not look familiar at all.
A cylinder, with male threads on one end, female on the other, with a cross-hole through it. Are you sure it isn't some adapter for some tool you have?
I have a brass adapter I use on my Fuel Pressure test gauge, that changes sizes on the fuel rail test port, to adapt the Ford test rail to the test gauge hose fitting. It doesn't have a cross-hole through the side of it, though.
Old Oct 16, 2022 | 11:49 PM
Prototypemech's Avatar
Prototypemech
Isn't that a thread checker tool? It has the same thread, one side is male, the other side is female. And it's usually on a ring or bead chain with a dozen other thread checkers.
Old Oct 17, 2022 | 06:44 AM
solanum's Avatar
solanum
Looks like a blow gun tip that someone accidentally dropped in the engine bay.
Old Oct 17, 2022 | 09:22 AM
Boz86's Avatar
Boz86
Holy cow! We have a winner. I don't understand why -- must have been really tired.
Now I can quite worrying and get this put back together
cdcava
16
Aug 8, 2022 03:33 PM
Whitey5.0
Feb 10, 2022 06:36 PM
Squirrel13
Nov 15, 2018 02:06 PM
PharmerChris
Oct 18, 2014 10:50 PM
strokin'_tatsch
17
Mar 23, 2010 12:38 AM
