93 F150 Pinging
Old Aug 5, 1999 | 12:30 AM
Don Boswell
Guest
Posts: n/a
93 F150 Pinging
I have a 93 F150 with a 5.0 engine. Its has pinged since day one. Tried different fuels, nothing. I saw a service report that suggested changing distributor. Changed dist, and module but to no avail. Any suggestions?
Old Aug 5, 1999 | 06:23 AM
dg's Avatar
dg
93 F150 Pinging
You have probably tried it, but I have heard of certain plug wires that have to be separated from each other. I think it is 3 from 4 and 7 from 8.
DG
Old Aug 11, 1999 | 03:26 PM
Ed's Avatar
Ed
93 F150 Pinging
>Any suggestions?
Mine used to do this also until the No. 8 rod bearing gave up at 64,000 miles. It seems that a problem with the 87-95 5.0L PCV suction from the No. 8 cylinder causes this syptom and may cause failure under load. After a new crank and No. 8 piston and pcv suction modification, its fine.
Old Aug 11, 1999 | 10:45 PM
moe's Avatar
moe
93 F150 Pinging
So what is the PCV vacuum mod? I have 900mi. on my 95 302HO I just installed in a 85 F150 and I'd like to get more than 60K from it. All I have is 1 line from the bottom of the AFB going to the PCV valve, and I'm not sure if it's all I need.
Thanks,
Moe
Old Aug 12, 1999 | 08:48 AM
Peter M. Howell
Guest
Posts: n/a
93 F150 Pinging
97F150RED
1997 - 2003 F150
Dec 5, 2009 12:06 PM
brrossi
Feb 22, 2007 01:09 PM
AerostarDad
Aerostar
Jul 11, 2004 01:46 AM
jams3
19
Aug 5, 2002 09:12 AM
psmallme
May 28, 2002 09:52 AM
