Aerostar Ford Aerostar
'93 4.0L pinging
Old Jun 18, 2004 | 09:04 PM
AerostarDad's Avatar
AerostarDad
'93 4.0L pinging
I just changed the plugs in my '93 Aero* 4.0L and now its pinging worse than before I changed them. Can someone tell me what the correct (or best) plug and heat range I should be using?
Thanks all
Old Jun 19, 2004 | 03:48 PM
kf4zra's Avatar
kf4zra
not sure how many miles you have. but you might also want to change the wires too. or use a higher grade of gas.
as the temp here in FL goes up, i have to start using at least 89 octane or i will get pinging, especially on the hwy.
Old Jun 20, 2004 | 01:08 AM
CanadianFordtech's Avatar
CanadianFordtech
Check your MAF sensor for contamination. Make sure screen in clear and clean. Also you can remove the 2 tamper-proof torx screws and clean off the two sensor wires of the MAF sensor.
Old Jul 11, 2004 | 01:46 AM
AerostarDad
Hey all!!!...I think I discovered the solution to my pinging problem. I replaced the plugs with what the parts store guy said were the right ones,AC Delco R44LTS. He says that what the book says.Well I checked my old plugs and they were Motorcraft 42's. I went and bought some new AC's,this time,R42LTS and,voila!!!...no more pinging.The book is WRONG!!! 2 heat ranges down cured my pinging. Just thought someone might benefit from my experience.
Thanks
Gary Rook
Apr 25, 2016 07:48 AM
t4kne
May 18, 2007 09:14 AM
VanGo
Aerostar
Feb 27, 2007 03:25 PM
tkrone
Jul 19, 2003 12:36 AM
citus
Oct 3, 2002 11:21 AM
