E4OD issues
Old Oct 15, 2022 | 09:33 PM
Stickle04's Avatar
Stickle04
2nd Gear
E4OD issues
Hey all. I have a 1992 f250 XLT with the E4OD in it. Bought it a few months ago and have had this issue since I got it.
When the truck has been running for a while, it has a tendency to kick out of OD and use it as a 2nd neutral so to speak. It won’t shift down into 3rd even if I press the OD button. It’s quite annoying as it normally requires me to stop and park to get it to shift through gears again and sometimes won’t rekick in OD leaving me to drive about 40 wherever I’m going. I’ve replaced the speed sensor and it helped by loads but it didn’t solve the issue. I’m being led to believe it’s something electrical since it hasn’t gotten worse while I’ve had it.
It also short shifts 3rd by a little and OD by a lot.
Any ideas for what I could look into would be appreciated as I don’t really have take it to a shop money at the moment.
Old Oct 16, 2022 | 03:14 AM
Prototypemech's Avatar
Prototypemech
Have you checked for codes? It's free and easy. Www.troublecodes.com/ford
Old Oct 16, 2022 | 09:52 AM
subford's Avatar
subford
Sounds like a bad MLPS (TR sensor).
TSB 95-06-19
Old Oct 16, 2022 | 11:03 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Which most likely will not trigger a fault code. Test the switch before replacing:
and another….
liberated from a subford post
Old Oct 16, 2022 | 12:23 PM
Stickle04's Avatar
Stickle04
2nd Gear
It doesn’t show a light for anything(not sure if OBD-I does or not) but I don’t have a scanner for one available.
Old Oct 16, 2022 | 12:46 PM
My4Fordtrucks
The light doesn’t need to be on for there to be codes. Do you have a paperclip?
Ethanskok
1997 - 2003 F150
Nov 22, 2019 08:35 PM
TripXAnarchy99
22
Jul 2, 2010 03:13 PM
StangMan
Feb 9, 2005 03:35 AM
StangMan
Feb 7, 2005 01:25 PM
wmcnally
Jan 12, 2003 06:25 PM
