1949 F-1 speedometer issue
Speedometer keeps “ eating” the replacement cables I install. Connection to transmission is fine as I can visually see cable turning with speedometer end in cab
Once attached to speedometer, the cable is “ eaten” by the speedometer ( destroying the tip.)
Seems the speedometer is frozen !!
Any thoughts?
Thanks
BSJ49
Any thoughts?
Thanks
BSJ49
Welcome to FTE. It sounds like you are not getting the cable properly seated in the back of the speedo. Take your question to the "Older, Classic and Antique Trucks" section. There you will find an entire group dedicated to the F! series trucks.
Don't forget to join you Maine state chapter too.
Thanks!
How do I get to Older /Antiquesection and to Maine Chapter
I did check how the “ seat “ was even to the point of taking a salvaged tip and measuring depth, compared it to new, then with it in my screw gun tried to activate speedometer. A lot of hopping and flutter, but nothing otherwise.
thanks for listening. I appreciate it
BSJ49
BSJ49
Any thoughts?
Thanks
BSJ49
Any thoughts?
Thanks
BSJ49
Thanks!
BSJ49
BSJ49
To get to any section, click on the, "Forums" tab at the top left of the page. The drop down will guided you to the various sections.
It's about 30% of the way down the main forums page, and can be found with this link: https://www.ford-trucks.com/forums/forum7/
Your truck would be best supported in the "1948 - 1956 F1, F100 & Larger F-Series Trucks" forum, second from the bottom in the Older, Classic & Antique Trucks section.
The "Maine Chapter" forum can be found near the bottom of the main forums page in the "Regional Chapters" section, under "New England Region" . . . and here: https://www.ford-trucks.com/forums/forum230/
Welcome aboard!
Removed the speedometer and used some WD-40 ( overnight!)
in am blew it out with air gun then let it dry and used graphite
spinning well at 50 MPH via Dewalt😊
thanks for your help
now, can I get it back in🥴
. . . and now you know how fast your Dewalt can go!
Continuing Speedo discussion
Speedo runs with an occasional flutter, but is reading 7moh under actual speed!
( nothing touched or changed except cable)
was there some adjustment that should have been made
thanks for your guidance
BSJ49
BSJ49
I used to rebuild speedometers a few years back. If it is off by 7mph all across the scale, you can CAREFULLY twist the needle while holding the speed cup (the round aluminum thing attached to the shaft the needle is attached to). If it is off by varying amounts you would need special tools to adjust it out (possibly a driven gear change in the transmission). A word of warning, keep magnets or magnetized tools far away as this will mess with the calibration. Also - do this adjustment at your own risk, I can't take any responsibility for a damaged component ><.
