Volt conductive loop
Old Oct 14, 2022 | 11:22 AM
firstrider's Avatar
firstrider
Will it pick up the correct amount if using plastic coated wire instead of cloth covered wire .? Truck buddy is building a '50 COE ramp truck to haul his '33 PU. . Told him I would ask around .
Old Oct 14, 2022 | 01:01 PM
hooler1's Avatar
hooler1
Are you talking about the inductive loop on the back of the charge/discharge ammeter? If so the anwer is the wires jacket material shouldn't make a difference. Unless it is some sort of sheilded cable that contains the inner conductor, insulation, woven wire or foil shield, then another cable jacket that the inner shield is grounded at one end or the other. Some of that is now common in newer vehicles. But as long as you are using standard, automotive wire or cable. It should work.
Old Oct 14, 2022 | 07:40 PM
49fordv8f4's Avatar
49fordv8f4
Mine works fine, but I did run the wire thru it the wrong direction.
Highwayman7043
16
Sep 10, 2021 03:20 PM
Dr G
Aug 23, 2016 08:41 PM
Outlaw56
32
Mar 16, 2014 02:45 PM
stumpy2
Garage & Workshop
Jan 30, 2004 06:41 AM
