Trans mount zf6
Old Oct 14, 2022 | 05:33 AM
Jamon Norton's Avatar
Jamon Norton
Trans mount zf6
I have been trying to figure out a driveline vibration on my 1999.5. Well come to find out the mechanic that installed the trans stripped the bolt holes in trans. I put longer bolts with washer/ lock washer and nut on other side. Hope this works, has any one else ran into this issue
Old Oct 15, 2022 | 01:54 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sounds like you did a good job on the repair. Were the bolts grade 5 or above? I imagine grade 3 will be OK but extra strength there is better.
Old Oct 15, 2022 | 06:23 AM
Jamon Norton
grade 8 I put a washer with bolt through trans from the bottom and the top I used washer, lock washer then a bolt. Once I got done I saw my loctite and wished I had put some of that in the mix too. Good news I did a roof for a guy that’s a mechanic and does performance and diesel so he is going to install my weld on traction bars. I’m thinking this is a big part of my vibration problem.
Bulldogmac
1997 - 2003 F150
Oct 15, 2019 08:22 AM
70torino429
Jul 10, 2011 10:14 AM
Drover
Apr 4, 2005 10:31 PM
