problem solved
Old Nov 12, 2003 | 07:24 AM
jdotoli's Avatar
jdotoli
Thumbs up problem solved
Hey Rockledge,
Thank you for the tip! I changed the Cannister Purge Solenoid / Flow Sensor, reset the "check engine light" and the warning light has remained off for over 100 miles. Hoo-ray!
One other question please. I need to replace the dimmer switch on the same vehicle, 95 Ford Ranger XLT 3.0L 5-speed. The manual says I need to take half the dashboard apart to get at the switch. It looks like if I take out the fuse box, which is in the dash just to the left of the switch then I will have easy access to the switch. Any recommendations?
Old Nov 12, 2003 | 10:50 AM
Ranger95's Avatar
Ranger95
Have to remove the dashboard. Will be easier that way, trust me.
Old Nov 12, 2003 | 11:01 AM
jdotoli's Avatar
jdotoli
OK, thanks.
Old Nov 12, 2003 | 01:52 PM
Rockledge's Avatar
Rockledge
Re: problem solved
Originally posted by jdotoli
Hey Rockledge,
Thank you for the tip! I changed the Cannister Purge Solenoid / Flow Sensor, reset the "check engine light" and the warning light has remained off for over 100 miles. Hoo-ray!...
Glad to hear it's working out for you ...chalk one up to the whole gang for that one, since I only learned more about it myself by hanging around FTE. Just passing along the info...
