*Help identify a part
Old Oct 13, 2022 | 09:54 AM
joeybaila's Avatar
joeybaila
2nd Gear
Hello,
Can some one pls help me identify if this part. I think its the part that goes into the transmission modulator, but am not sure. And if anyone has a pic of what the pin inside a C6 modulator looks like, can you please post. Thank you in advance!! Some
Old Oct 13, 2022 | 01:14 PM
Crop Duster's Avatar
Crop Duster
Don't have a pic of one but that looks like one. If you think it was left out just pull the modulator and see if it has one in it. A word of advice, when you pull a modulator jack the rear end way up and put jack stands under the axle. Otherwise, unless you are a real fast worker you will take a bath in trans fluid.
Old Oct 27, 2022 | 09:48 PM
joeybaila's Avatar
joeybaila
2nd Gear
Thank you for the help. I plan on putting it back in this weekend. I had a problem with the tranny where it would not go into 1, 3, or D, but would go into Reverse. The shifter rod was hitting on the exhaust, and had the exhaust moved an inch left. I then was able to drive it home, but took me 3 times putting it into D, and now it won't go into drive at all, or 1 , 2 , any ideas. ?
Old Oct 28, 2022 | 09:01 AM
FuzzFace2's Avatar
FuzzFace2
What is the ATF level at and how dose it look in color red or brown and smell like
Dave ----
Joe Ryan
1978 - 1996 Big Bronco
May 9, 2022 08:59 PM
Donnylad
Oct 31, 2021 06:20 AM
bigoldtruck
Jul 24, 2021 01:42 PM
roadrash63
Mar 8, 2016 08:09 PM
