Burning transmission fluid
Old Nov 12, 2003 | 06:27 AM
mayerst's Avatar
mayerst
I have a 91 Explorer v-6 auto, and am losing much trans fluid. I am finding that the inside of some of my vacuum hoses have trans fluid in them. Any ideas on a fix or where to start? Thanks in advance!!! I appreciate the help!
Tom
Old Nov 12, 2003 | 06:33 AM
luckild's Avatar
luckild
replace the modulator on the trans. good luck.
Old Nov 12, 2003 | 07:51 AM
mayerst's Avatar
mayerst
Thanks, didn't know if this trans had a modulator, its my brothers truck I'll try it.
Thanks a lot
Tom
Old Nov 12, 2003 | 06:18 PM
rclarke's Avatar
rclarke
The vacumn modulator is on the passenger side of the transmission. It is a little difficult to reach but if you lower the transmission crossmember and work with the catalitic convertor cool you can get to it. There is one bolt just above the modulator (10mm head). Be careful not to loose the pin in the modulator, it needs to go back in the new modulator.
Old Nov 13, 2003 | 05:53 AM
mayerst's Avatar
mayerst
Thanks, thats a big help!!!!!
Tom
tip49
Jun 30, 2014 03:28 PM
380tom
Jan 25, 2013 10:35 AM
tip49
18
Sep 13, 2006 05:42 PM
fomocotuff
Oct 4, 2002 03:30 PM
