Have Ford F-250 2012
Code B1086 has appeared I replaced Blend door actuator still doesn't work. I also replaced control panel before replacing Module.
Code U2100 has also appeared . I hope can find out which way to find the issue.
Thanks,John
Welcome! You'll be given all the answers you need if you pist this in the Super Duty section.
