99 f350 crew, I have replaced all my door actuators and my driver door lock/unlock switch. My passenger switch makes all the doors locks function as intended but my driver door lock switch still doesn't work. I have also purchased new fobs for the door locks and my pickup wont go into programing mode to program them. Are the two issues related? Where do I go from here?
The folks that know about this sort of thing don't often visit the "New Member Introductions" forum. You'll probably get some great answers over in the "1999 to 2016 Super Duty" forum.
CathedralCub is right about the page views ME70
I think you just have a couple of more bad switches and to get the key fob programming figured out
The door lock / unlock switches all communicate with the master switch in the drivers door
So if they all work from say the RH door switch, your problem is most likely just another failed switch
At the dealer I would take a hand full of new door (satellite) switches they call them and plug them in
That will either fix it or you have broken wiring in to the doors somewhere (usually inside the drivers door rubber boot)
With the NGS scan tool I can operate all of your power locks and check the switches individually
Makes it a little easier
