New Owner Questions
I've noticed there is a Dorman EGR valve installed. Is there a general consensus on whether those should be genuine Ford products (like electronic components) or is aftermarket OK?
Also, the dust caps/dust seals on the end of the front axles are loose and are outward of the rubber lip thing on the axle shaft. How critical are those and can they be reseated somehow without pulling the axle out? 4WD does not disengage properly (need to manually flip hubs), so I may have to mess with the axles anyway.
Anything else I should be initially aware of? I've got Torque Pro and am working to get that set up for the 6.0L. I've got limited data on temperature deltas - they generally seem to be around 8-10 degrees cruising on the freeway, and they seem to drop to 5-8 if I'm climbing up a moderate incline. I'm sure more questions will follow.
Greg
Yes, the general consensus is that MOST of the time OEM is best. A few exceptions:
04.5 and up - EGR cooler (get one from BulletProof Diesel)
All FICM's - upgrading them from a reliable source is HIGHLY recommended
Coolant - you REALLY need to upgrade to an EC-1 rated ELC coolant if it hasn't been already
The dust seals really do not do much. They can help keep the axle tube clean, but that is only a benefit when you are removing and then re-inserting the axles.
The OEM hubs are vacuum operated, so is it a loss f vacuum that is causing the problem with the 4x4 (ie the hubs not engaging when you flip the switch)? Usually when you have a vacuum issue, the climate control will default to defrost. Is that what is happening?
If so, you can be having vacuum issues that can come from quite a few places. The first one to check is to see if the vacuum hose that runs to the heater control valve is off. If it is not that vacuum line, then it could be a leak from any of the lines, could be one or both of the 4x4 hubs leaking at the seal, or it could be a vacuum pump issue.
I hate almost everything from Dorman, but if you are not getting an EGR valve code, then maybe replacing it can take the back burner.
From what you posted, there doesn't seem to be an issue with the oil cooler.
I was looking through the previous owner's service receipts this morning. It looks like the Ford dealer deduced that that the 4WD system was holding vacuum and they recommended hub replacement. Although I bought it a couple weeks ago, I haven't really driven it much yet. I'll have to check on the operation of climate controls to see if anything like you've described is happening.
What is your position on the importance of monitoring EGTs with the 6.0. I installed a pyrometer on my 7.3 since EGTs on those could creep up. Not sure if it is crucial on these. I probably won't be towing much until spring and even then it would be probably 5,000 lb or less with a boat. I do plan to install a fuel pressure gauge when time permits.
Vacuum pump motor concerns on the Ford 6.0 f250-f350 Powerstrokes Superduty - YouTube
-jokester
I would do fuel pressure first as you can lose injectors quickly if that drops off.
While I'm stock, I've installed EGT sensors on both sides. It's not that I'm worried about excessive temperature, but I think it will be a good tell if an injector over-fuels, which usually ends up burning out a cylinder. It's not a tested situation, and an over-fuel will have visual tells, but half the year I run at night and that can be a long tow. So a duel T/C gauge was added.
Way too many people believe the bolts are the problem on this engine; it's the heads.
