Auto Relock
Old Oct 8, 2022 | 07:49 AM
lemforder's Avatar
lemforder
Auto Relock
Anybody able to get Auto Relock to work with Forscan?
I tried it by changing the BCM per the spreadsheet but it did not work.
Mine is a 2022 model year.
Thanks
Old Oct 8, 2022 | 08:07 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
What is "auto relock"???
Old Oct 8, 2022 | 08:18 AM
lemforder's Avatar
lemforder
The Auto Relock System is a security feature that automatically locks your vehicle after it's been left unlocked for a certain period.
Old Oct 8, 2022 | 08:22 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Never heard of it before.
Old Oct 8, 2022 | 09:06 AM
lemforder's Avatar
lemforder
I had never heard of it either before looking at the Forscan spreadsheet
Old Oct 8, 2022 | 11:41 AM
4wd6.7L's Avatar
4wd6.7L
Isn't it so when you unlock without actually opening the door, it will re lock after a set period of time if the door has not been opened? I considered making that change with Forscan but never did.
That feature is standard on many cars. I have 2 import brand vehicles pushing 20 years old that do it.
Old Oct 8, 2022 | 04:31 PM
lemforder's Avatar
lemforder
I’ll have to try unlocking the door and not opening it and see if it will lock.
I thought it what it did was lock itself if it was unlocked, regardless after a period of time (either 30 or 45 seconds based on the Forscan spreadsheet).
Old Oct 8, 2022 | 04:50 PM
4wd6.7L's Avatar
4wd6.7L
That would be extremely annoying if it locked after 30 or 45 seconds regardless of whether the door has been opened or not. The Forscan change should just make it like my Toyota, relocks 30 seconds after the door was unlocked if the door hasn't been opened.
Old Oct 8, 2022 | 06:48 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
I have auto relock enabled. It is covered in the ForScan thread. It is actually a PIA. I found it and got it to work, but after having it for a while. I will be disabling it.
ZooDad
Old Oct 8, 2022 | 07:02 PM
4wd6.7L's Avatar
4wd6.7L
ZooDad
As I mentioned earlier I have it on 2 other vehicles I own, it has never bothered be or been an inconvenience in any way. I haven't enabled it in the Super Duty just because I haven't felt much of a need. I am curious what it is that you don't like and makes it a PIA for you?
Old Oct 9, 2022 | 10:58 AM
B-ManFX4's Avatar
B-ManFX4
If you unlock the truck with a keyfob or with FordPass and you don't open a door within xx seconds (set via Forscan) the truck will lock the doors.
If you shut the truck off and walk away without locking the doors they will remain unlocked until you lock them via whatever method you choose.
Old Oct 9, 2022 | 11:06 AM
lemforder's Avatar
lemforder
I appreciate the feedback.
Jamiebasspro
2015 - 2020 F150
18
Mar 11, 2020 01:48 PM
Fomoko1
May 2, 2009 08:31 AM
