4.9 refresh questions.
Old Oct 5, 2022 | 07:48 AM
b00mhower's Avatar
b00mhower
Trailering
Currently in the process of removing a busted spark plug in my 91 F-150, 4.9L 4x2 automagic. Decided to take the intake plenum off for a little more elbow room and set to wondering what else I should check on or replace while I'm digging into it. Already have a distributor, plugs, and wires going in but wasn't sure if I should go ahead and dig deeper to save myself a return trip down the line. Insights, comments, concerns, anything you got is appreciated.
Thanks in advance
Old Oct 5, 2022 | 08:34 AM
AuroraGirl's Avatar
AuroraGirl
Thanks in advance
chase all spark plug threads and probably wise to clean up cylinder 6 if you are willing to pull the head(all of them, but 6 prob looks the worst)
Old Oct 5, 2022 | 10:45 AM
b00mhower's Avatar
b00mhower
Trailering
I was hoping to not pull the head unless I had to but I'm not opposed to it. Why cylinder 6 specifically?
Old Oct 5, 2022 | 11:06 AM
cannothinkofaname's Avatar
cannothinkofaname
vacuum lines might be easier with the intake plenum off. especially the ones which go behind the motor. You could clean the injectors. https://www.ford-trucks.com/forums/1...to-thread.html
clean the IAC valve, inspect the air charge sensor. clean the EGR. The injector kit comes with the gaskets to remove most of the intake.
Old Oct 5, 2022 | 11:40 AM
AuroraGirl's Avatar
AuroraGirl
if you dont want to pull the head, skip it, I said that for mechanical reasons, 6 tends to get leanest hottest or maybe it was carbon build up. what can said about vacuum lines 100% do those that run behind. also pcv and grommets for pcv + breather
Old Oct 5, 2022 | 11:41 AM
b00mhower's Avatar
b00mhower
Trailering
beautiful, all of that just made the checklist thank you
Old Oct 5, 2022 | 10:30 PM
Moongypsy's Avatar
Moongypsy
Have you done a compression check? After purchasing my truck last year I replaced the plugs and had a hell-of-a-time removing #5 spark plug. The only large job I thought was needed was an exhaust manifold gasket, but after a compression check found two hairline cracks in the head for valves 3 and 5 and a pinhole in the block at cylinder 5. The previous owner filled the engine with stop leak instead of fixing the issue early. Now we're putting in a reconditioned motor...
Old Oct 6, 2022 | 09:52 AM
b00mhower's Avatar
b00mhower
Trailering
This was originally my grandpas truck so I know it didn't have a real hard life but it did sit for long periods of time, if I can get the busted plug out I'll throw the tester on but if I pull the head I'll send it off for good measure
Pitbull17
2009 - 2014 F150
Apr 22, 2016 11:28 AM
DoofusOfTheDay
Nov 16, 2012 12:46 PM
1925mosin
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 16, 2012 10:37 PM
ptm
1983 - 2012 Ranger & B-Series
May 8, 2008 10:29 AM
NeedHelpBad
May 28, 2003 05:29 PM
