Tailgate trim removal
Old Oct 4, 2022 | 04:36 PM
JohnnyGaloshes's Avatar
JohnnyGaloshes
I need to remove the tailgate trim, ladder and the handle assembly on my 2018 F350 XLT. Anyone do this before? Does the top piece just snap off and the ladder held in with a couple bolts if i recall reading. Thanks!
Old Oct 6, 2022 | 06:26 AM
lemforder's Avatar
lemforder
If you're referring to the tailgate steps, this should help.
Old Oct 6, 2022 | 08:15 AM
mewaschuk's Avatar
mewaschuk
the plastic cap just pulls off (snapped on). basically single use unfortunately because you can't easily release the snaps. the metal underneath is very thin and flimsy. just cut the snap tabs off as you go.
Old Oct 6, 2022 | 02:29 PM
dchjort's Avatar
dchjort
4wd Low
Also if you have a upper trim with the gate trim panel you will need thies clips as you will brake several of them. Even though they are for a JEEP thies are a exact match for ours
Rexka 20pcs Rocker Wheel Flare Moulding Clips Compatible with Jeep Grand Cherokee Compass Cherokee 68172491AA 68271803AA 68395627AA GM 11571175 19352782 Traverse
Feardeere7
Mar 20, 2013 08:41 PM
CanadianBigBlue460
38
Feb 28, 2011 08:11 PM
BRBuzz151
1978 - 1996 Big Bronco
Feb 25, 2005 11:22 PM
trk98
Oct 28, 2004 11:52 PM
