Sponsored by: Real Truck
Running issues
Old Oct 2, 2022 | 05:30 PM
Jkonks's Avatar
Jkonks
Trailering
Running issues
Hi all I have a 01 f250 5.4l that I recently changed the driver's side head gasket on and now It runs like crap and has low power, the stft is high on both banks witch made me think vacuum leak and after looking everywhere and doing the starting fluid method I came up empty handed
my question is if the timing chain was off one tooth on the one head would that cause the problem I'm having?
Old Oct 3, 2022 | 08:21 PM
99f350sd's Avatar
99f350sd
I suppose it would run like crap. Have you checked the coil wires make sure you don't have them backwards on the wrong cyl...prob hard to do...take a compression test on that bank.
Old Oct 3, 2022 | 09:26 PM
Jkonks's Avatar
Jkonks
Trailering
Yeah can't really get wires mixed up, I did compression check on the head I had off to make sure I got compression back after I changed gasket cylinder 6,7 only had 20 psi before I started!
Old Oct 4, 2022 | 09:41 AM
Djosbun's Avatar
Djosbun
A vacuum leak would lead to a lean running condition (negative fuel trim readings). Use a bore scope to see if any pistons are wet due to injector bleed-down.
— Dave
Old Oct 4, 2022 | 09:51 AM
Jkonks's Avatar
Jkonks
Trailering
— Dave
Wouldn't checking fuel rail pressure tell me the same thing?
Old Oct 4, 2022 | 12:51 PM
Djosbun's Avatar
Djosbun
You’ll need to perform an injector buzz test to locate a bleed-down issue. Can also pinch off the PVC hose to see if the STFT’s come back up to zero (which will guide you down another path).
— Dave
Old Oct 4, 2022 | 01:09 PM
Jkonks's Avatar
Jkonks
Trailering
— Dave
Thanks I'll give that a try
" Injector buzz test" not familiar with that termIs that the test with the noid light?
Old Oct 4, 2022 | 01:33 PM
Jkonks's Avatar
Jkonks
Trailering
So when I looked up buzz test it looks like It pertains to diesel injectors I have a 5.4L
Old Oct 4, 2022 | 02:42 PM
Djosbun's Avatar
Djosbun
You can buzz any fuel injector. I do it regularly. You’ll need a specific tool and pressure gauge to measure the pressure drop.
— Dave
Old Oct 4, 2022 | 02:54 PM
Jkonks's Avatar
Jkonks
Trailering
— Dave
Ok thanks I'll do some deeper digging into that!
Jkonks
Modular V8 (4.6L, 5.4L)
Oct 4, 2022 08:09 PM
GreenDually
1997 - 2003 F150
Nov 17, 2014 02:46 AM
Ravenous Weasel
Feb 24, 2012 09:57 PM
Sealcoat City
Modular V10 (6.8l)
27
Apr 9, 2009 06:15 PM
umdstang
1997 - 2003 F150
Dec 9, 2004 01:55 AM
