Modular V10 (6.8l)
V-10 gear ratios?
Old Nov 11, 2003 | 08:29 PM
kameronth's Avatar
kameronth
Question V-10 gear ratios?
I drive a Bronco but my father owns a 2000 f-250 V-10. He bought it a year used and was never told the gear ratio. Is ther a way to find out? Is it tagged on the truck somewhere?
Old Nov 11, 2003 | 08:58 PM
v10Mustang's Avatar
v10Mustang
look at the tag on the rear end.......
it will have a few numbers and letters on the upper row and the on the bottom row the first numbers will look something like this
3L73 8.8
3L73 10.25
3 55 9.75
and so on and so on
the first set of numbers is the rear end ratio
the second set is the size of the rear end
The "L" is if you have a traction lock or not......if you don't it will be a blank space
usually the first number is kinda hidden by the bolt that holds it on
so if you only make out like "L10" or something like that you'll have a locker with 4.10's
and so on and so on
hope this helps.........might have been over kill though
Old Nov 11, 2003 | 09:24 PM
HeavyAssault's Avatar
HeavyAssault
You will find either 3.73s or 4.30s in the V10s if the truck is stock. Limited slip will be an option as well.
Old Nov 12, 2003 | 09:00 AM
Fords For Ever's Avatar
Fords For Ever
Another way to find the diff ratio is to look at the "vehicle certification label" on the drivers door jamb under axle code.
C1=3.73 limited slip
31=3.73
C3=4.30 limited slip
33=4.30
3.73's should do about 2000rpm at 70 mph and 4.30's should do about 2,300 rpm at the same speed with an automatic. Hope this helps.
