E99 No Crank Resolved
Old Oct 2, 2022 | 09:27 AM
Tomkat07's Avatar
Tomkat07
I performed battery and starter cable replacement and upgrades including two new batteries, a new alternator and fender mounted starter solenoid.
https://www.ford-trucks.com/forums/1...now-worse.html
I replaced the solenoid in effort to chase down a no crank situation. With the problem unresolved, research led me to this:
And that was the problem, the ignition switch mounted under the steering column. $25 later and the truck cranks and fires reliably.
Edited to add: See update below.
Old Oct 2, 2022 | 08:55 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Awesome thanks for checking in with the fix!
Old Oct 3, 2022 | 07:46 AM
FordTruckNoob's Avatar
FordTruckNoob
Good on you for posting an update for closure. Incidentally, these things come back to life nicely with a spritz of quality contact cleaner.
Old Oct 3, 2022 | 09:51 AM
Tomkat07's Avatar
Tomkat07
Update: I go out the next morning to the truck to again have a no crank situation. The new Auto Zone solenoid wouldn't crank the starter when I touch the small solenoid lug to battery positive. I put the old, OEM Ford solenoid back in and it cranked and fired right up. I just tried it again this morning and again fired right up.
I replaced this OEM solenoid as a prophylactic measure, given the it's likely original to the truck, without testing it thoroughly. I'm leaning to all OEM parts from here on out.
Auto Zone solenoid is going back to the store, and I'll pick up the upper radiator hose that routes around the serpentine belt.
Old Oct 3, 2022 | 10:03 AM
FordTruckNoob
The 3-post Trombetta is a pretty nice upgrade for the fender-mounted starter relay.
New OEM Trombetta Relay Solenoid...
Amazon Amazon
Old Oct 3, 2022 | 11:31 AM
Tomkat07's Avatar
Tomkat07
New OEM Trombetta Relay Solenoid... https://www.amazon.com/dp/B01EB8389Q...p_mob_ap_share
Thanks for this. I'm going to order one, install it and rotate the working older one as a spare.
gigglygoose04
Jan 21, 2022 10:50 AM
laloacosta
May 3, 2021 08:16 PM
CHOPTASTIC93
1997 - 2003 F150
Sep 22, 2014 05:18 PM
Emyl
18
Jun 19, 2013 07:41 PM
1FastGambler
17
May 15, 2011 12:40 PM
