Rear Shackle question.
Old Oct 1, 2022 | 08:55 AM
tiger100's Avatar
tiger100
A friend has a 48F2, the rear spring shackles are worn oval, I have a 51 Mercury frame with same? shackles.
The Ford shackle fits on the back of spring,..... and the Mercury shackle fits to the front.
Both use a 21/4inch wide spring....At first glance the shackles look the same..
Question, Would Henry have gone to the expense of different shackles ..Or, are they interchangeable.?...
Thanks for all and any answers.
Geoff.
Old Oct 2, 2022 | 08:49 AM
tiger100's Avatar
tiger100
rear shackle question
Does anyone have an answer?
Old Oct 2, 2022 | 02:08 PM
rusty48's Avatar
rusty48
One would assume there the same, but without seeing just a guess. Since it seems your going to pull the worn out ones out? Are you sure a new busing wont work?
Old Oct 2, 2022 | 06:16 PM
tiger100's Avatar
tiger100
rear shackle question.
rusty48
The guy with the Ford tells me his are worn oval, and were past repair. We were wondering if the Mercury shackles were the same,
provided of course that they aren't past their use by date. The only way to find out is to pull 'em and see.
Geoff
Old Oct 3, 2022 | 04:40 AM
fish pond's Avatar
fish pond
Smile
I do not understand your question, I have a 51 M3, my rear springs,shackles are on the back, Mine were wore oval, I bought oversize bushings from McMaster Carr and machined the shackles to except them, I did the machine work,perhaps pictures of your parts mite help,??
I am not sure,but perhaps why the folks are not answering may be because they do not understand either,perhaps??
Yup
Greg
Old Oct 3, 2022 | 08:20 AM
tiger100's Avatar
tiger100
Fish Pond
OOOPs I blew it. I'm going 'round the bend! You're right, the Mercury shackle fits to the rear!
The question was ..Are the Ford and Mercury shackles the same? Will they interchange?
The OP says his are worn beyond repair, Thanks for the lead to Mcmaster Carr
I just looked, and they have dealers in Canada..... I will tell him about your result.
Thanks ...Geoff.
Old Oct 4, 2022 | 10:20 AM
33ratrod's Avatar
33ratrod
I have a 1951 F-3 and the rear shackles were worn had them welded and machined back out for the new bushings. Hard to find a shop to weld cast iron but if you look hard enough there out there.
Old Oct 6, 2022 | 12:17 PM
tonyguns's Avatar
tonyguns
I also had mine repaired by a local hotrod shop. They welded, rebored them and they came out perfect. They are unobtanium new.
bigdan1979f-250
Offroad & 4x4
Apr 1, 2013 07:50 PM
labman1014
Jul 28, 2011 04:14 PM
thendrix
Jan 19, 2011 07:59 PM
stm250
May 12, 2009 12:19 AM
mlf72f250
Jun 26, 2002 04:57 AM
