Dual tank question
Old Sep 30, 2022 | 08:29 AM
Bletendre3536's Avatar
Bletendre3536
2nd Gear
Dual tank question
Has anyone done or know anyone who has done a front tank delete? My front tank in my 1990 f250 was rusted real bad and toasted the pump, i don’t have the money right now to replace the tank and pump so would it still all work the same if i plum the fuel lines straight through and cap off the wiring? Or is it just smarter to save the money for a little and replace the tank and pump?
Im not the worlds greatest mechanic but i can get myself around when i work on stuff. I appreciate any help i can get. Thank you in advance
Old Sep 30, 2022 | 11:51 AM
cannothinkofaname's Avatar
cannothinkofaname
Welcome to the forum.
This thread asked a similar question
https://www.ford-trucks.com/forums/1...2-f-150-a.html
Old Sep 30, 2022 | 01:00 PM
My4Fordtrucks's Avatar
My4Fordtrucks
If, at some point, you plan on replacing the tank, why not leave it alone and simply not use that tank?
There is a way to delete the tank and terminate the lines without causing other issues. I’d have to search the forum to find the procedure.
Old Oct 3, 2022 | 12:29 PM
evan_nugget's Avatar
evan_nugget
Best way is just to use the connections from the old fuel pump - create block offs for the pressure and return lines by cutting them off at the OLD fuel pump, blocking up the ends however you like, and then re-connecting them.
I used a ziploc bag to cover the vent tube (to charcoal canister) and the plug for the fuel pump. I ran without a back tank for almost a year this way, with no leaks.
Cb2004
Jan 25, 2022 07:53 AM
Ransom Murica
Aug 1, 2021 08:55 AM
JYost17
Nov 5, 2016 09:55 AM
dickiefrank
Jan 9, 2015 04:45 AM
bdinger
16
Feb 5, 2006 05:27 PM
