messed up alignment
Old Sep 29, 2022 | 11:10 AM
Rhorn61's Avatar
Rhorn61
4wd High
messed up alignment
So lately i replaced the ball joints upper and lower plus tie rod ends when i put everything back together sat the truck on the ground notice my tires on both sides have a bad postive camber and i know have to bring it to a shop to get a alignment but is there any way i can try to fix the camber first?
Old Sep 29, 2022 | 11:25 AM
SFaulken's Avatar
SFaulken
Drive it forward about 50 feet, and see if it's still that bad. If you've only got to drive it a mile or two to the alignment shop, don't worry about it, it just might make some funny noises till you get there, and steer funny, it won't appreciably hurt the tires.
Old Sep 29, 2022 | 11:53 AM
Rhorn61's Avatar
Rhorn61
4wd High
thanks for the info ive heard it could have to much toe or my camber is way off im just wondering what they will charge for the alignment and what the problem may be
Old Sep 29, 2022 | 12:03 PM
SFaulken's Avatar
SFaulken
When I had the alignment done on my F150 a couple months back, after doing the ball joints and tie rods, my local shop charged me right around $100. *but* I didn't need any camber bushings, as my front end was close enough to align with the bushings that were in it. If they need to get camber bushings, it's probably going to be closer to $200
Old Sep 29, 2022 | 12:09 PM
Rhorn61's Avatar
Rhorn61
4wd High
thats what my problem going to be the stock camber bushings i know they gonna have to replace its a very significant amount of postive camber.
Old Sep 29, 2022 | 12:47 PM
SFaulken's Avatar
SFaulken
No, its not. You unloaded the front suspension when you had it in the air to do the work. This is the nature of a TTB or Twin I-Beam front suspension, you *need* to drive the truck forward about fifty feet, and reload the suspension, before you start claiming the sky is falling. Move the truck forward, and then evaluate how bad the camber issue is. Even in the *best* case, the camber bushings only correct up to something like 3-4° of camber. If you drive the truck forward, and you still need more than that, you've got other issues.
Old Sep 29, 2022 | 01:14 PM
Rhorn61's Avatar
Rhorn61
4wd High
did the drive the truck the other day it kinda corrected itself some
Old Sep 29, 2022 | 03:02 PM
sandymane's Avatar
sandymane
He has a 2WD truck and it will only allow about 2 degrees adjustment even with adjustable bushings because of the passenger knuckle.
yeahoner
Mar 22, 2019 02:16 PM
PSDLOVER
Jun 28, 2009 10:23 AM
wresleu
Aerostar
15
Jan 12, 2006 06:34 PM
88grandmarquis
May 7, 2003 08:24 PM
