CPP Brake switch
Old Sep 28, 2022 | 08:47 PM
CJMOStang's Avatar
CJMOStang
CPP Brake switch
From what I can tell from the wiring diagram for my ‘49 F1 the master cylinder brake switch was to activate the brake lights. I just bought the CPP complete kit. Where have some of you who bought the same kit put the switch? Is there a spot on the prop valve I am missing or are you using one dlfront wheel outlet on the prop valve for the switch and splitting the other later?
I didn’t have 45 minutes today at work to spend on customer service so any help would be appreciated
Old Sep 28, 2022 | 09:23 PM
56panelford's Avatar
56panelford
This is how it came set up from CPP but I disliked the switch because the pedal required a lot of pressure before the brake lights came on so I installed a switch at the pedal instead which worked instantly..
Old Oct 1, 2022 | 05:25 AM
Marten's Avatar
Marten
Are you talking about a fluid switch that goes in the brake line? If so, I bought one from Midfifty, POS, failed shortly after I started driving and it leaked fluid out as well. Switched to an electric switch on the pedel.
Old Oct 1, 2022 | 08:21 AM
ingo's Avatar
ingo
i don´t like the hydraulic brakelight switches, so i use motorcycle brakelight switches mostly.
Old Oct 1, 2022 | 09:03 AM
moejr's Avatar
moejr
Like ingo, i replaced the the line pressure switch with a motorcycle brake light switch.
willie71
Jun 23, 2022 01:05 PM
77ford250
Sep 8, 2020 12:04 AM
Ryan Sigman
Jan 24, 2013 06:17 PM
dynamic
Electrical Systems/Wiring
Nov 13, 2005 10:26 AM
53Merc
Jun 30, 2004 10:14 PM
