truck height
Old Sep 28, 2022 | 06:27 PM
Todd1's Avatar
Todd1
truck height
I'm going to order a 2023 crew f250 and am trying to figure out if it will fit in my garage. I have 82.5 inches of clearance. Is the platinum with 20 inch wheels taller then the lariat with 18 inch wheels?
Thanks,
Old Sep 28, 2022 | 06:51 PM
Mike in CA's Avatar
Mike in CA
Thanks,
It depends a little on tire brand, but in general, the 275x65x20 tire on the Platinum will be about 34" in diameter while the 275x65x18 tire on the Lariat will be about 32". So all else being equal, the Platinum will sit about 1" higher with those tire and wheel combos.
Ford says the height of the 4x4 Crew Cab is 81.5". The question is, what trim level, options (like satellite radio with the antenna bump) and what tire/wheel combo are they using for that measurement? If it's a base XL with 245x75x17's (31.5") then both the Lariat and Platinum will be a bit taller than 81.5.
Since you only have, at best, an inch to play with things could get really tight and might come down to how much air you have in the tires!
Old Sep 29, 2022 | 10:43 AM
Todd1's Avatar
Todd1
Thanks for the info
gblaz123
May 14, 2011 10:19 AM
Ronzi
Offroad & 4x4
Apr 25, 2010 05:20 PM
