Howdy folks.
I have a 2001 f250 7.3 bone stock 550xxx miles.
Runs like a dream except at idle. I am pretty sure I have a leaking injector. Starts clear then after about 20 seconds starts white diesel smoke and a hell of a lot of it.
At idle it builds up. I punch it and it bogs down and blows hella white smoke then changes to black and starts haulin ***.
I have an AE with ford package. I know how to use it. I do not understand the data it presents to me.
Only codes it is throwing are "intake air heater" which I have a bad relay on but its been like that for at least 10 years and not been a problem
and its throwing and exhaust back pressure code which I cant really sort out.
also...cel stays on except when I back off the accelerator after a hard push then the light goes off until I accelerate again.
I know how to ohm the 42 and the uvch which I learned years ago on this forum. Everything seems to check out.
I have shimmed these injectors twice. I have put orings on them about every 2 years...the cheap ones.
If someone could sorta lead me down the proper diagnostic path, I would greatly appreciate it.
I just am not sure how to isolate the problem injector.
when mine started acting up, i found some bad O rings, but i also know i need new injectors, it will come! It may have just come for you!
X-4 on new injectors
Maybe the next time I have a Corvette engine specific question I'll just post in any ol subcategory somewhere on a Chevy forum. Then I'll insult the forum when no one knowledgeable stumbles across it in the wrong section and tell the members I'm going to a forum dedicated to that specific engine platform....
Fix **** that ain't broke... That's your solution...
I don't fix unbroken ****.
I asked how to isolate the bad injector
By your logic, if the headlight goes out I should replace the truck.
Super helpful.
Great forum
Have you changed also the internal injector orings?
x3 for new injectors.
no, I have not.
I would like to try.
Just bought a 81 f150 to bum around I'm while I tear down the power stroke.
I just wanted to isolate which injector was the problem.
Apparently though, the best solution from this forum is just to start throwing $1000s of dollars worth of parts at it or just pull the fuel cap and replace the truck.
no, I have not.
doing internal seals and nothing else is a good way to waste a $1,000 of ones time and have it run worse.
500+k is nothing to complain about. Replace worn out parts with fresh good quality parts, and keep on trucking.
