Throttle Valve Linkage
Old Sep 26, 2022 | 07:28 PM
grzzly71's Avatar
grzzly71
How can i "tie down" kick lever?
Old Sep 26, 2022 | 08:21 PM
grzzly71's Avatar
grzzly71
I found this website..
https://www.kickdownrods.com/
i couldn't find exact one, can you guys see which one could work?
Old Sep 26, 2022 | 08:33 PM
5851a's Avatar
5851a
Your modulator is hooked to ported vacuum, remove the hose from the side of the carb and hook it to manifold vacuum. Your distributor should be hooked the port on the side of the carb. Install a tee fitting where the brake booster is hooked to intake, hook modulator hose to that Tee. Just cap port on carb, try moving distributor hose over later if transmission works ok.
Old Sep 26, 2022 | 11:08 PM
440 sixpack's Avatar
440 sixpack
You want to tie it up not down. and i should hold itself up but it didn't sound like it was.
5851 has it figured out, if you're on ported for your transmission it's not going to shift right it has to have manifold vacuum.
Old Sep 27, 2022 | 12:10 AM
1TonBasecamp's Avatar
1TonBasecamp
[QUOTE=grzzly71;20570905]AAMCO also called it the passing gear rod. Does that make sense?[/QUOTE]
Yes.
Might not be it’s official name, but it is in fact what it does.
It “kicks down” from 3rd to 2nd when you push the throttle far enough.
Old Sep 27, 2022 | 03:06 AM
benbuilder's Avatar
benbuilder
I have a c6 kickdown, if interested send me a pm
Thanks
Old Oct 1, 2022 | 06:42 PM
grzzly71's Avatar
grzzly71
Is everybody in agreement that the modulator is being vacuumed wrong? If so can you tell me where it should go. Can you look at picture for reference on how it's hooked up now? Thank you.
Current connections..
Old Oct 2, 2022 | 01:17 PM
5851a's Avatar
5851a
Hook it to same port as the vacuum line to your brake booster. I looks like with your manifold you may need to add a T fitting.
Old Oct 2, 2022 | 01:25 PM
tbear853's Avatar
tbear853
Originally Posted by grzzly71
1973 F250 4x4 390 C6 transmission.
picture of truck for reference only...
Yet another problem with Big Mamu..
Had transmission rebuilt. Truck won't shift past 3rd gear. Was told I need the throttle valve linkage. Cant find it anywhere. Can you guys help me?
It onl;y has three forward gears.
When im driving the truck, i can manually shift from 1 to 2 the D but I dont get nothing after that. The engine revs high and transmission wont give me another gear. If it in D itll only shift if i release the throttle up until what i am calling 3rd gear. Nothing after that. Engine is REving real high. Im afraid im gonna blow my engine..
After 1st & 2nd & 3rd, there is only Neutral, then Reverse and finally .... Park.
Old Oct 2, 2022 | 01:54 PM
grzzly71's Avatar
grzzly71
Going to pick this up tomorrow. This should work right? Local shop in Corona has some.
Old Oct 2, 2022 | 01:56 PM
1TonBasecamp
You are missing what is commonly referred to as a “vacuum tree“ at the back of your manifold.
Where the single large hose for the brake booster is fitted to a single barbed fitting (presumably) most passenger cars and trucks of the era would’ve had a multi port vacuum manifold many of which did look like a tree with multiple barbed hose fittings of various sizes protruding from it.
Some were in fact as simple as manifolds, being just a square brass block with a couple of fittings soldered to it, but most were tree like.
See if you can find a multi port version and replace the single barbed fitting with one that will accommodate all of your needs. A model with at least one 3/8 inch fitting and a couple of the smaller ones.
That would be the typical location for connecting the transmission vacuum modulator and the vacuum brake booster.
The one to the upper part of the carburetor air cleaner flange that runs down to the exhaust manifold is correct. That is your choke stove intake that allows clean air to run through it down to the exhaust manifold to be preheated before running back up to the automatic choke on the carburetor.
if you haven’t already, make sure your PCV valve runs from one valve cover to a 3/8 inch hose fitting that is in the common plenum area at the base of the carburetor or top of the intake manifold beneath the carburetor.
Or on many Fords it was located in a spacer plate under the carburetor.
Old Oct 2, 2022 | 01:58 PM
1TonBasecamp
Bingo.
that would work, but count how many vacuum lines you have that need full vacuum and maybe find one that has more than just two ports if needed.
Otherwise if it’s just the brake booster and the transmission modulator, that one would be perfect.
Old Oct 8, 2022 | 10:44 AM
  #28
grzzly71's Avatar
grzzly71
Originally Posted by NateWagner
It will drive fine with the kickdown tied off. The governor will kick it back to 2 and 1 when speed decreases. Lot of guys drive them without kickdown attached. I'm kind of wondering if you are in 4 Lo since you say its revving so high and won't go over 35. Another thing to note, if you've never run old trucks, lots of these had 4.10 gears and will rev much higher than modern vehicles with OD transmissions and lock up converters. You can run it at 2500-3000 RPM all day. That's how it was designed.
Nate..looks like you were right as well. Truck was in 4L. I messed with the 4wd shifter and walla...it's rolling down the highway at 55-60 mph..Thank you all for the advice.
File Type: mp4
Old Oct 8, 2022 | 10:53 AM
  #29
grzzly71's Avatar
grzzly71
I have 1 more question regarding this issue (hopefully). Currently carb is hooked up as shown in following pictures. Seems to me throttle spring might be wrong because it's hooked up to where the kick down rod(which I found one at local junk yard) is supposed to hook up.
I believe this is where kick down rod goes..
Should that spring be there?
Can the spring and kickdown rod be in the same spot?
What are these holes for? Should spring be pulling the other way?
Old Oct 8, 2022 | 11:58 AM
  #30
tbear853's Avatar
tbear853
I know, not the same carb ... but if you use a throttle return spring below thw throttle shaft in thos lower holes, you need to anchor it to a bracket that once was at the rear. Notice the blue spring.
I had to fashion an extension for my kickdown because the 4 barrel carb moves the throttle shaft forward on the intake.
