Right turn signal problems
Old Sep 25, 2022 | 07:17 PM
wagaskyc's Avatar
wagaskyc
Trailering
Whenever I use my right turn signal my left front signal flashes too, and if I have my headlights on the indicator on my dashboard for the right turn signal is steadily on, and when I go to signal right nothing changes. I know it's probably an issue with the wiring somewhere, just wondering if anyone can point me in the right direction.
Old Sep 26, 2022 | 07:10 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Check and clean the grounds at the bulb fixture.
Old Sep 26, 2022 | 07:24 AM
i-w's Avatar
i-w
Maybe this might help.
But i just had a problem like this.
i cleaned all contacts for each bulb and socket they went in to. EVEN the marker lights.
i used an emery board and cut it with scissors to fit in the marker light socket.
Amazon Amazon
Old Sep 26, 2022 | 07:46 AM
wagaskyc's Avatar
wagaskyc
Trailering
Thanks, I'll try cleaning everything when I get back home this afternoon, and I'll let you guys know how it goes.
Old Sep 27, 2022 | 12:39 AM
wagaskyc's Avatar
wagaskyc
Trailering
Got home and cleaned all the connections to the lights and the grounds, and it still wasn't working, so then I sprayed some cleaner on the blinker thing (not sure the actual name) in the column itself, and that fixed it, so I'm getting that sensor thing was just dirty, thanks for all the help.
Old Sep 27, 2022 | 06:57 AM
77&79F250's Avatar
77&79F250
That "blinker thing" is called a Turning Signal Switch. At least you got it fixed, you know a cheap Chilton or Haynes manual from the local parts store will help learning the basic names and basic maint stuff.
https://www.oreillyauto.com/detail/c...=manuals&pos=1
https://www.oreillyauto.com/detail/c...=manuals&pos=2
Amazon Amazon
Old Sep 29, 2022 | 12:13 PM
i-w's Avatar
i-w
my actual blinker relay was bad. it was so slow it blinked like once a minute. LOL
the element inside was worn out for sure. new blinker relay now it works like new.
my blinker lights no longer show or dimly glow at night.
questie760
Aug 19, 2022 07:55 PM
TedsRed250
Sep 24, 2021 02:09 PM
greenterror
Electrical Systems/Wiring
Apr 9, 2004 06:58 AM
CrashMaster
Oct 10, 2003 01:07 AM
sixte1f100
Apr 28, 2000 10:13 PM
