Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2011 Escape brake light problem
Old Sep 24, 2022 | 04:10 PM
Grayfox54's Avatar
Grayfox54
Trailering
I recently bought a 2011 Escape XLT. I discovered the brake lights don't work.
Let me preface this by saying I'm a retired truck and equipment mechanic. While I never worked on cars much, I can generally fix whatever comes up. The principals are all the same.
So I got to checking into the problem. I have power to the switch. I can run a jumper on the connector and the brakes lights do come on. Simple right, bad switch. But a new switch didn't fix it. In fact I've tried three new switches, the last one being a Ford factory switch. None of them work. I tested all 3 with a multi-meter and none are showing a connection.
Has anybody ever heard of this before or have any idea what the Hell is going on? What am I missing?
Old Sep 24, 2022 | 04:32 PM
projectSHO89's Avatar
projectSHO89
What am I missing?
Do you have the circuit schematic?
1. Do any of the brake lights work (high, corners) when the pedal is pressed?
2. Is the switch being "made" when the pedal is pressed?
3. Which wires did you jump to force the lights on?
4. Which of the four connections on the switch do not show a closed circuit when the switch is "made"? Should be pins1-4 for the stop lamp circuit. Pins 2-3 are normally closed and should open when switch is made.
Old Sep 24, 2022 | 04:58 PM
Grayfox54's Avatar
Grayfox54
Trailering
No brake lights work anywhere. Tail, turn signals and flashers all work properly.
I was able to get a schematic of the lighting system.
Looking at the back of the switch when mounted. Left to right
Terminal 1 Violet/ white stripe goes to the brake lights.
Terminals 2 &3 run the shift lock and whatever else.
Terminal 4 Yellow with red stripe is power and goes directly to fuse #2. This wire is hot.
I can run a jumper from terminal 1 to terminal 4 and the brake lights do come on.
I've tested all 3 new switches with a multi meter. On all 3 switches terminals 2 &3 are open in the pushed position and make contact in the released position. just as they should
However, terminals 1 &4 do NOT make contact in either position
It keeps coming up as a bad switch. But 3 different brand new switches form 3 separate vendors all being bad? Am I missing something here?
Old Sep 24, 2022 | 05:20 PM
projectSHO89
Sounds like a run of bad luck.. You know what they say, "*stuff* happens.
I agree, three bad switches in a row. You're doing everything right.
Unless..... there's a problem with the socket/pigtail or the switches are getting fried upon installation.... I'd check the next replacement with a meter before leaving the parts store.
Old Sep 24, 2022 | 05:28 PM
Grayfox54's Avatar
Grayfox54
Trailering
Gotta give NAPA a shot tomorrow. And yes, I will check it before buying.
Old Sep 26, 2022 | 09:10 AM
scott91370's Avatar
scott91370
Are you able to test it before mounting it?
Kind of sounds loike the switch is not adjusted correctly. I know many vehicles you can turn them in/out to get them close/further form the brake pedal so the plunger/switch touches the pedal arm. I hope that makes sense.
Old Sep 26, 2022 | 10:15 AM
projectSHO89
He's already moved to and beyond that step.
Old Sep 26, 2022 | 10:28 AM
Grayfox54's Avatar
Grayfox54
Trailering
They're working!
I've been fiddling with this thing off and on for a couple of days now. I did replace the switch, a couple of fuses and repaired a couple of wires. But honestly, I can't say exactly what fixed it. All I know is they're working now.
I still can't figure out why several different switches never showed a connection in either position with the multi-meter?
BTW: there is no adjustment on the switch. It just fits in the bracket and turns to lock.
Old Sep 26, 2022 | 02:55 PM
projectSHO89
Was it yet another new switch or is it working with one of the previous ones that previously didn't work out?
Old Sep 26, 2022 | 04:00 PM
Grayfox54's Avatar
Grayfox54
Trailering
It was a new switch.
idler50
20
Jul 27, 2018 02:12 PM
missviv2
Nov 1, 2006 12:07 PM
Big D.
15
Mar 13, 2005 01:44 AM
phmco
1997 - 2003 F150
Nov 15, 2003 07:35 PM
Darvit
Jul 30, 2003 02:06 PM
