Powersteering
Old Sep 22, 2022 | 08:39 AM
Mspangler's Avatar
Mspangler
4wd Low
Powersteering
Hey Y'all I know a lot of people have done this, but I can't find any straight answers, I'm trying to put a power steering gearbox on my 1972 ford. I currently have one from a 1979 I was going to put on it, but some say it won't fit and that a different one is needed. Any suggestions?
Old Sep 22, 2022 | 10:25 AM
RichS2659's Avatar
RichS2659
Let's get this straight: you need to give us basic info, 2wd/4wd, F-100/250, modifications done, to enable someone to answer your questions. We are not mindreaders here.
Old Sep 22, 2022 | 12:12 PM
Mspangler's Avatar
Mspangler
4wd Low
Oops my bad. It's a 4wd f250 with a inline 6 and a 4 speed transmission.
Old Sep 22, 2022 | 02:38 PM
RichS2659's Avatar
RichS2659
You have several options for PS. You can get a kit from Battleborn Brakes to use your 79 F-250 box, or you can use a kit from Benchwork Steering which has their own box. Or do it yourself.
https://www.battlebornbrakes.com/pro...73-77-f250-4wd
https://benchworksteering.com/produc...ing-conversion
If you decide to use your PS box, I would recommend sending it to Red Head Steering Gears or Blue Top Steering Gears to get professionally rebuilt.
Benchwork also has a PS pump kit for your 6 using the excellent Saginaw canned ham pump.
https://benchworksteering.com/products/ford-300-6-cylinder-saginaw-power-steering-pump-kit
https://www.ford-trucks.com/forums/849572-4x4-power-steering-swap-articles.html
Old Sep 22, 2022 | 03:32 PM
Mspangler's Avatar
Mspangler
4wd Low
Ok thank you for the options I really appreciate it.
Old Sep 26, 2022 | 08:49 PM
hoffy's Avatar
hoffy
I have a 1971 F250 4 x 4 And I used the 1979 F250 power steering box. It takes a little bit of welding but overall pretty easy project. I also did the Saginaw power steering pump mod. I’m very happy I did both of them the ps system works really good. I have a couple of pictures in my album If you want to see what it looks like. Good luck
Old Oct 29, 2022 | 04:15 PM
My1966f250highboy's Avatar
My1966f250highboy
4th Gear
Electric power steering
Has anyone tried the electric power steering conversion for f250 highboys. It sounds too good to be true. Opinions always welcome
Old Oct 30, 2022 | 12:41 AM
1browski's Avatar
1browski
https://www.ford-trucks.com/forums/1...with-epas.html.
Old Oct 30, 2022 | 08:18 AM
Acluff's Avatar
Acluff
I have a used one for sale in the marketplace. It works great, I ran into an issue when I was installing a new upgraded steering column which is the only reason I’m selling. The EPS has adjustability to the amount of assist it has so you can turn it down if you’re doing a lot of highway and turn up is you’re operating in close quarters with a lot of turning. I thought it’s a pretty neat setup.
Old Oct 30, 2022 | 10:21 AM
My1966f250highboy
4th Gear
Excellent, how much
SteveEford1
General Automotive Discussion
Nov 23, 2010 08:51 AM
radramrod2
Feb 5, 2007 02:56 PM
1933edpickup
1947 and Older Ford Trucks
Feb 25, 2003 10:00 PM
