Fuel Pump Relay
Old Sep 21, 2022 | 07:22 PM
Swamp Truck's Avatar
Swamp Truck
Fuel Pump Relay
Hello,
My truck is an 85 F-150 XLT Lariat, I believe the relay pictured is for the fuel pump if someone could verify that would be great.
I am having trouble finding a relay with 4 prongs. Every one I find has 5. Will that work? I attached some pics, as you can see it is very corroded. Will an electric cleaner work or is it to far gone. Thanks for any assistance. I have been working on this truck for several years when I have time and I think I tracked down one of the last remaining issues with this relay. The PO let it sit up for about 5 years. It is located on the driver fender.
Thanks in advance from the Pascagoula Swamp.
Old Sep 21, 2022 | 08:15 PM
kr98664's Avatar
kr98664
Looks like Standard Motor Products RY46 will work. The OEM number is in the cross-reference list:
Sorry, my phone is acting up and won’t properly paste a link. Search for the OEM number (no spaces) and one of the first hits is RockAuto. Click on “installation instructions” and it says it will replace 4 or 5 prong relays.
If the 5th prong gets in the way, cut it off. It’s not needed.
Old Sep 22, 2022 | 01:07 AM
FuzzFace2's Avatar
FuzzFace2
I think someone posted not long ago that the 5 pin relay will work.
Look at the socket and I think it is made for the 5 pin but just not used.
Dave ----
Old Sep 22, 2022 | 06:13 PM
Swamp Truck
Thanks, that helps a lot. Is the female connector a universal part or is it specific?
Old Sep 22, 2022 | 07:55 PM
Franklin2's Avatar
Franklin2
If you are going to replace the relay socket also, you could just get a universal Bosch type relay and use that. Here it is with the socket and pigtails.
Amazon Amazon
Old Sep 22, 2022 | 09:48 PM
Swamp Truck
That's definitely the cheaper route, but I am not good with electricity so I don't know if I can match up the wires since the connections are different.
Old Sep 23, 2022 | 05:04 AM
kr98664's Avatar
kr98664
We can walk you through it if you’d like to go that route. Should be a piece of cake with only four wires to match up.
Old Sep 23, 2022 | 07:42 AM
Swamp Truck
That would be awesome! I'll get the part and take some pics of the wires.
Old Sep 23, 2022 | 07:53 AM
Franklin2's Avatar
Franklin2
Here's a diagram if you decide to go that route.
catequipment's Avatar
catequipment
Napa also sells the socket and relay. I just bought the socket for my truck. It was an exact match. The only downside was it was around $20
Old Sep 23, 2022 | 07:54 AM
catequipment
This is good info. Would this also work for the EEC relay?
Old Sep 23, 2022 | 11:26 AM
Franklin2's Avatar
Franklin2
Yes, but of course with different wire colors. Ford doesn't have the market locked in on 12 volt relays, but they do on the oddball ones they spec'd out and used. You just have to be willing to do a little wiring, and if you have to change the socket, you will be doing that anyway.
evaleriano
Nov 17, 2021 10:21 AM
swihart_art
Aug 21, 2017 07:36 PM
fgcox1
Nov 5, 2015 02:39 AM
danos94
Jul 22, 2010 12:49 AM
jasonjason
Feb 18, 2008 05:19 PM
