A Cautionary Tale
Old Nov 3, 2015 | 01:21 PM
fgcox1's Avatar
fgcox1
A Cautionary Tale
If you are having fuel pump intermittent issues, be aware that most relays are not sealed to the atmosphere.
I was driving along and all of a sudden, no gas. Bypassed the FP Relay to get home.
Tool the relay apart and here is what I found. Relay is less than a year old!
On the new replacement I have used silicone sealant to prevent this again.
Old Nov 3, 2015 | 02:10 PM
Franklin2's Avatar
Franklin2
Was that relay mounted upside down?
Old Nov 3, 2015 | 02:17 PM
fgcox1's Avatar
fgcox1
Nope, right side up and on fender wall
Old Nov 4, 2015 | 06:52 PM
SpencerS's Avatar
SpencerS
I also have had issues with that relay, although mine is not mounted on the fender. Even had some wires going to it completely burn up one time. Like, there is still melted insulator on the wheel well. Thankfully my dad is good at working on electrical stuff. But when that relay fails my truck wont run for more than 30 seconds at a time. And a peculier thing is that the original only had 4 prongs on the inside whereas the replacements i get have 5. But it still works.
Old Nov 5, 2015 | 02:39 AM
tempest411's Avatar
tempest411
For that, and other reasons I have replaced the factory style with waterproof Bosch style relays. The replacement relays, and probably the originals to begin with, just didn't have the production numbers behind them for manufacturers to spend the money making the Ford ones to a very high standard.
V10man
Electrical Systems/Wiring
Dec 1, 2012 11:27 AM
Shattered
Sep 21, 2012 11:04 AM
Jessef250
Jan 9, 2011 05:06 PM
danos94
Jul 22, 2010 12:49 AM
