New Pushrods for Modded 302
Old Sep 20, 2022 | 08:06 AM
Blsstradius's Avatar
Blsstradius
All,
here’s a Question for those that have upgraded their 302 engines -
ive got a set of Edelbrock E street heads ready to install on my NA 1984 F150 302W.
plus - a Comp Cams Extreme Energy hydraulic flat tappet cam.
the rockers haven’t been purchased yet and neither have the hardened steel pushrods.
Question- simply - How do I determine the pushrod length I need?
I am thinking I’ll need to install the rockers and the camshaft and then use an adjustable pushrod to get the proper length measured and THEN order the appropriate length hardened steel pushrod set.
i think the stock pushrod length for the stock configuration is 6.900 inch but I seriously doubt stock length pushrods, although they’d probably work, certainly wouldn’t be the best choice
thanks!!
Old Sep 20, 2022 | 08:24 AM
FuzzFace2's Avatar
FuzzFace2
That is how I would do it.
Dave ----
Old Sep 20, 2022 | 02:33 PM
Franklin2's Avatar
Franklin2
Your new heads will have guide plates and adjustable rocker arms correct? So the length is not as critical, since you now have a adjustable valve train. So long as the geometry is close. When the valve is open you want the rocker to be close to center on the valve tip.
I would call edelbrock if in doubt.
Old Sep 20, 2022 | 05:02 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Dave ----
Same here. Buy an adjustable pushrod checker to make sure the length you need.
Old Sep 21, 2022 | 07:20 AM
Blsstradius
The Edelbrock (5103) E Street aluminum heads are assembled but they do not include rocker arms or pushrods. I need to purchase rocker arms and pushrods separately.
Old Sep 21, 2022 | 01:49 PM
88n94's Avatar
88n94
Originally Posted by Blsstradius
The Edelbrock (5103) E Street aluminum heads are assembled but they do not include rocker arms or pushrods. .
ALUMINUM HEADS?? Do they provide you with the head gaskets? Or any special instructions? With all the trouble Ford and other companies had with aluminum heads when they first became available you would need different head gaskets.
Old Sep 21, 2022 | 06:08 PM
Old Hickory's Avatar
Old Hickory
If the heads have guide plates on them you will need harden push rods to use with them.
Old Sep 22, 2022 | 08:05 AM
Blsstradius
Pushrod length
yes, you’re correct. After doing some more reading - with the hydraulic flat tappet camshaft I have, I adjust each rocker / valve for zero lash and therefore, pushrod length shouldn’t be critical.
thank you
Old Sep 22, 2022 | 08:06 AM
Blsstradius
you bet. Thanks
Old Sep 22, 2022 | 08:15 AM
Blsstradius
aftermarket aluminum cylinder heads for the 302 have been around for 40 years +
Gasket selection is simple (you’re definately not going to use the same type OEM head gaskets) but like every other mechanical assembly, surface preparation is critical as is replacement of those 40 year old head bolts (that have gone through thousands of heat cycles) with new, quality fasteners and proper torque techniques and values.
Old Sep 22, 2022 | 08:38 AM
Franklin2's Avatar
Franklin2
thank you
Stock length would be a place to start, but with all that aftermarket stuff put together you still need to eyeball the geometry when it's all put together. If you use roller rockers, you do not want the back of the rocker where the pushrod goes kicked way up in the air, and the roller half-way off the valve tip. The other extreme would be the pushrod end being very short, and again the roller end would be way over to the side of the valve tip. You would think these people would have their act together and try to stay somewhat close to what the factory had as far as length, but things happen sometimes. Blocks get milled, valve tips get ground, heads get decked, etc.
Old Sep 22, 2022 | 11:29 AM
My4Fordtrucks
So why start with stock length and then eyeball it to make sure everything is sitting where it should? Why not use an adjustable pushrod checker on an intake and an exhaust valve to actually make the pushrod the necessary length and then order the correct part from the start?
Old Sep 22, 2022 | 12:46 PM
Franklin2's Avatar
Franklin2
Because maybe he has some stock ones laying around? Otherwise the checker would be the way to go. Of course the stock one would be just to check things out, he could not use the stock pushrods with the guide plates.
olblue77
Sep 16, 2017 10:41 AM
bedmondo
Dec 10, 2007 04:15 PM
gunman_sr5
May 4, 2006 01:13 PM
Ringo Fonebone
Jun 10, 2004 07:17 PM
locknload
Aug 28, 2003 08:27 PM
