Spooks are back !!
Old Sep 19, 2022 | 06:51 PM
SaltySenior's Avatar
SaltySenior
Spooks are back !!
Having this problem the last few months...every so often ,the battery will be dead , mainly in the A M ....battery checks o k and does good until the problem occurs again ..... when trying to jump star, the result is still no cranking....seems like something is shorting out but it does this when it feels like...garage told me to use a new key and that seemed to work for a month or so...every thing works fine until it decides to drain the battery again...2008 E-150 V8
Hard to explain what is happening w/o sounding like a Nerd...
Old Sep 19, 2022 | 07:48 PM
econo93's Avatar
econo93
Sounds like something is draining your battery. Troubleshoot accordingly:
https://www.aa1car.com/library/battery_runs_down.htm
Old Sep 19, 2022 | 09:50 PM
SaltySenior
Reason 3 on the list seems to fill the bill,,,problem is trying to locate it WHILE it is doing harm..../seems to correct itself as the battery is recharged...it was in the shop for a week and it did not do it's dirty deed..............???
Old Sep 20, 2022 | 04:00 AM
JWA's Avatar
JWA
When this next event occurs first order is to measure/check the battery's condition at that moment; voltage at that time and what CCA's are available. Then when started check the alternator's output.
I would suspect failed diodes inside the alternator. Most excessive parasitic draws typically do not drain a fully charged battery over night whereas failed diodes can.
Good luck with this!
Old Oct 4, 2022 | 04:33 PM
SaltySenior
Put in a new battery....ran the van around the block 5 times in 5 days,.....all OK...after it sat the 6th day overnite the battery was dead and showed 3.4v in the A M ....disconnected the neg. post and the battery came back itself to 10.9v....Have a charger on now....any thoughts ????
Old Oct 4, 2022 | 06:19 PM
tabijan's Avatar
tabijan
Do you have a second battery under the side door?
Sixto
07 E350 5.4 183K miles
Old Oct 4, 2022 | 06:44 PM
SaltySenior
no just one battery under the hood..
Old Oct 4, 2022 | 08:14 PM
econo93's Avatar
econo93
Put in a new battery....after it sat the 6th day overnite the battery was dead and showed 3.4v in the A M ....disconnected the neg. post and the battery came back itself to 10.9v....Have a charger on now....any thoughts ????
Have you had the alternator/charging system checked?
Have you done the battery drain checks?
It's obvious you have a drain somewhere. Start pulling fuses.
Old Oct 5, 2022 | 04:49 AM
JWA's Avatar
JWA
Still sounds suspiciously like failed alternator diodes---those need to be check by someone who knows how to do this properly. This video may be helpful if this becomes a DIY project:
Good luck!
Old Oct 5, 2022 | 07:57 AM
SaltySenior
The alternator will charge the battery.....it seems the problem does not happen all the time.....can the diodes fail and then repair themselves,,,,what ever pulls down the battery does it's deed when it feels like....one occurrence happened when I drove 5 blocks to our pool . van sat for 1 and 1/2 hour and would not crank....jumper cables used and it still would not crank ..tow truck guy put jumpers on and still no crank..gauges on dash flickering...when it got to the garage they charge up the battery and watched and started it for 4 days.. all o k ....../took it home and 6 days later the battery died overnight....
Old Oct 6, 2022 | 06:19 AM
JWA's Avatar
JWA
Check for failed alternator diodes or not---your van, your issues to deal with especially if you're avoiding a simple test. It's also possible the starter is failing but if the battery seems to be a consistent issue we're back to failed or failing alternator diodes.
Some components can have intermittent issues so they never really repair themselves. The recurring issue of a dead battery has us right back at possible failed alternator diodes once again.
Old Oct 6, 2022 | 01:00 PM
econo93's Avatar
econo93
no crank....jumper cables used and it still would not crank ..tow truck guy put jumpers on and still no crank..gauges on dash flickering...when it got to the garage they charge up the battery and watched and started it for 4 days.. all o k ....../took it home and 6 days later the battery died overnight....
What did the shop say about it not cranking even with jumpers? Did they also try to jump it or just recharged the battery?
It's related to the dying battery somehow but really that's a problem all by itself.
Old Oct 6, 2022 | 05:20 PM
maples01's Avatar
maples01
Time to remove the alternator and take it to the shop, this is the only way to fix this.
Old Oct 6, 2022 | 06:14 PM
SaltySenior
The shop said they put a charger on it and it started the next A M....said they cleaned the terminals and it was OK for 4 days at the shop ...I was leary about the terminal theory because the jumper cables clamp on the cable clamps ......can the alternator be tested while in the van ???? and if it is alternator problem , can they find it even when it is acting o K ???? like I tried to explain this only occurs when it feels like....sorta like my posted question about static on my speakers....
Old Oct 6, 2022 | 06:17 PM
SaltySenior
