c-6 something wrong
Old Nov 11, 2003 | 05:14 PM
butchf250's Avatar
butchf250
c-6 something wrong
hey guys i hope someone nos when i start my truck its a 78 f250 4/4 c-6 it trys two move ahead while its still in park you can fill it any one no HELP
Old Nov 11, 2003 | 07:05 PM
BigBully's Avatar
BigBully
Its normal The fluid in the Torque Converter starts Pumping and pressurizing the system so you will feel it try to move the truck
Old Nov 11, 2003 | 11:46 PM
Torky2's Avatar
Torky2
In Park & Neutral there should be no drive through the trans. No clutches or band should be applied. Try re-centering the manual shift valve by adjusting the shift linkage:
Wheels chocked, parking brake ON. Engine off, put it in Drive. Go under the truck and loosen the adjusting nut on the shifter arm. Click the shifter arm on the trans 1 click forward, 1 back. So it is back in Drive, using the detent that is inside of the trans. Go back up to the cab, and verify that the shift selector up there is solidly in the Drive position. Then without moving anything, tighten the adjusting nut.
Now that the manual valve is for sure centered, see if it wants to pull in Park, or Neutral. If it still does, you have bigger problems.
