Shifting linkage
Old Sep 18, 2022 | 09:38 AM
79 problems's Avatar
79 problems
4wd Low
Shifting linkage
I have 79 F-150 Ranger 2wd 302 aod and still has factory 2barrell carb. Transmission went out. Had a friend of friend pull it out to fix or swap the transmission. Long story short never seen transmission or guy again and recently put a newer aod in now I have no shifting linkage or TV rod and don't see any wires or plug for nss. What type of shifting linkage from what years of vehicles would work?
Old Sep 18, 2022 | 10:13 AM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
Are you sure you have a AOD transmission in that truck?
From what I seen that transmission was not used in trucks till think mid 80's.
If that is the case then you will need to look at mid 80's trucks for needed parts ans even then may need to rework them to work in your truck?
If it is a AOD then it does not use a computer but dose use a TV cable and if not adjusted right the trans will burn up in no time so has to be adjusted right from the get go.
One of the big issues is how the cable hooks to the carb as the carbs for the AOD trans have a different cable hook up.
I hear the kits sold to hook the cable to after market carbs dont work right and need reworking to work right.
As for the NSS I dont know if on the trans or on the column in your year truck?
Do you know where the back up light switch is?
Dave ----
Old Sep 18, 2022 | 10:22 AM
79 problems
4wd Low
No I have not found backup switch yet
Old Sep 18, 2022 | 10:25 AM
79 problems
4wd Low
This is the new transmission
Old Sep 18, 2022 | 10:30 AM
79 problems
4wd Low
Previous owner must of converted to the aod
Old Sep 18, 2022 | 10:40 AM
79 problems
4wd Low
My diagram showes the netural and backup switch are one and its no where on truck
Old Sep 18, 2022 | 10:56 AM
dlburch's Avatar
dlburch
It's shown on your picture above right above the shifter screwed into the trans. You just need to get the harness for the correct year Trans and wire it to your truck's factory harness.
Old Sep 18, 2022 | 11:36 AM
tbear853's Avatar
tbear853
I don't think an AOD will last long without a TV cable? Maybe wrong, I no longer have any AODs.
Old Sep 18, 2022 | 03:36 PM
79 problems
4wd Low
I have the nss plug for this new er transmission can't find the existing plug and or wires to bypass or hook up to. I know about how important tv cable is to aod I don't drive it but want to I found and made a custom linkage but not right. If I pull the shifter in to first gear position the shift display shows it in neutral. Not sure if that is bad but i would like it to show im in proper spot. So just want to start with proper linkage whitch don't exist considering my truck proly came with the c4 so what linkage I had b4 was modified is my hypothesis or will factory linkage for c4 work?
Old Sep 19, 2022 | 05:17 PM
85e150's Avatar
85e150
Your truck predates the AOD by a year, so you'll have to look for linkage from an '80 or up.
The shift display is probably a mechanical indicator behind the window--something you might be able to adjust or fiddle with if you can get into the steering column or behind the dash.
This is a TV cable, there are several flavors you can check to see which one might work for trucks:
Amazon Amazon
There is an electrical plug in this picture:
https://cimg1.ibsrv.net/gimg/www.for...03fe1a7805.jpg
Should be NNS and/or backup lights.
You MUST have the TV cable for up and down shifts. Otherwise, you'll be in the wrong gear at the wrong time with transmission failure to follow.
As to if OEM C4 linkage would work, it probably would have to be modified.
OEM AOD linkage is out there, as this was installed in trucks.
More aftermarket linkage for the whole thing:
Amazon Amazon
Old Sep 20, 2022 | 02:00 PM
79 problems
4wd Low
Thanks for replying. I'm try junkyard yard as soon as I can for linkage I work nights and might have to sacrifice a night's sleep. Is it possible linkage from a Ford car in that 80-85 year area with 302 aod would fitment? Cause pretty sure our junkyard only has 4x4 p/u. A pic of oem linkage would be nice if possible
Old Sep 21, 2022 | 07:54 PM
85e150's Avatar
85e150
Gotta be a truck due to the dimensions involved. You'll come up short with a car setup--although you could mod it to fit.
The AOD lasted until '83, with the AODE being the following version.
83f150xlt
Jan 31, 2017 06:30 PM
Leeboy1962
Feb 23, 2014 02:48 PM
A73F100
Jan 14, 2014 07:50 PM
lewismorton6655
Mar 2, 2011 10:34 PM
ClemsonLightning
Nov 15, 2004 11:33 PM
