4.9L E40D Flexplate Question
Old Sep 17, 2022 | 08:47 AM
theworstshadetreemechanic's Avatar
1994 F150 4.9l with E40D.
Had to replace the flexplate due to the other one cracking.
Does anyone have a trick to line the torque converter up to the flexplate?
Does the the flexplate have a certain position it needs to be at, as in balance with this particular year?
Does the torque converter need to be at a certain position with the flexplate?
Thank you for your help.
Old Sep 18, 2022 | 08:05 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The flexplate holes will only line up to the crankshaft one way. Keep turning the flexplate until all the holes line up.
No. The torque converter does not need to be lined up any particular way.
Old Sep 18, 2022 | 07:10 PM
Thank you. I got it done this afternoon, used an allen wrench to feel the torque converter stud and line it up. Now it's time to torque everything down (and not forget some thread lock this time), throw the harness back on, reconnect the drive shafts, fix my rotted fuel vent line, and redo the entire shot rear suspension
kawboy125
Feb 12, 2010 09:38 PM
rkymtnman30
Sep 22, 2007 09:12 PM
cujo8
May 9, 2006 10:39 AM
