Sponsored by: Real Truck
Engine slowing down while driving
Old Sep 14, 2022 | 01:37 PM
droptoppop's Avatar
droptoppop
5th Gear
HELP!!!
Set out for the store today and less than a mile down the road the engine slowed down while I was holding the pedal at the same place. When I let off the pedal and hit it again the truck sped up. A little further down the road it width same thing, let-off and pumping the pedal got it going again. It did this probably 4 or 5 times in the first couple miles so I turned around to bring it back home.
It feels like I let off the gas but Im holding the pedal steady.
2014 F350 DRW 6.7L 108,000 mi
Checked the OBD codes with my scanner and there were none.
DEF level says it's good
Old Sep 14, 2022 | 03:22 PM
cj45lc's Avatar
cj45lc
My 2016 6.7 did the same thing & I got code P 1102 MAF sensor with the engine light on. Reset it & got the same thing a little later with no code but engine light back on.
Runs like crap for a few seconds then picks back up.
Old Sep 23, 2022 | 04:38 PM
droptoppop's Avatar
droptoppop
5th Gear
Turns out the problem was this little switch
Picked up a replacement switch at AutoZone and it's plunger was 3/16 longer than the one from the factory and the black wings on the barrel were all bent up. Brake pedal test looks good, lights up and stays off, test drive proved it was working properly now, no slowdowns and even the cruise control held just fine.
tkerkela
Jun 11, 2010 05:12 AM
n20
Mar 29, 2010 02:34 PM
chris86924
Apr 19, 2009 05:14 PM
Kelsokell
30
Mar 17, 2006 11:24 AM
Dwights
Mar 23, 2002 07:48 PM
