Compass Stuck On North
Old Sep 14, 2022 | 08:30 AM
Mark250's Avatar
Mark250
I've seen some discussion on this but not really an answer. Recently the compass on my 2018 with Sync 3 always reads N, on the dash and on the compass on the screen. I disconnected the batteries for a few minutes and no change. No I did not change the setting to true north, and not it has not been sitting in the same position for a long period.
Another weird thing is I have my display on the night setting so it's not so bright. I like the black background. Been like this for 3 years and all of a sudden it goes to a daytime setting every time I start it. Change it back and it does the same thing.
Any ideas?
Old Sep 14, 2022 | 10:13 AM
Reverend Jim's Avatar
Reverend Jim
Veteran: Navy
Have you tried doing a full reset on the radio itself? Not by disconnecting the batteries, the radio unit has an internal memory. Go to the settings menu and scroll through until you find the reset section and follow the prompts. You will have to re-enter your radio presets and pair your phone if you use one through Bluetooth. I had to do this on my wife's Explorer for similar conditions. Also, have you checked your battery(s) lately? The radio messing up is usually one of the first symptoms of a weak or failing battery cell in my experience with previous the Fords I have owned.
Old Sep 14, 2022 | 01:13 PM
Mark250's Avatar
Mark250
Reverend Jim, yes I did a system reset on the Sync 3. My batteries are still spinning the starter over like the day I got it, but I guess I check into them.
mbw919
2015 - 2020 F150
Nov 20, 2021 10:40 AM
alexstjo
Aug 24, 2018 06:22 AM
ChiefsFan
Kansas Chapter
Apr 8, 2004 06:08 AM
