DEF warning question
Old Sep 19, 2022 | 04:26 PM
hooper303's Avatar
hooper303
There should be a code starting with P0 that shows up when you scan it. My 2021 had a bad DEF system and that message would come on and resolve itself again and again. Sometimes the code said low or no flow.
Old Sep 19, 2022 | 05:55 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by speakerfritz
where are you reading that in plain English?
If he has to explain the humor, then it isn't funny.
Old Nov 21, 2022 | 04:26 AM
Gwilkrrs's Avatar
Gwilkrrs
so i havent pulled any codes yet. i have a code for the nox sensor that needs fixed but nothing for the def. i will keep the reader with me and when i get the warning i will try to pull it but it seems to be so intermediate when i turn the key off it doesnt catch the code?
i still havnt figured the ob2 and phone for forescan........
Old Nov 21, 2022 | 12:53 PM
mcmurm's Avatar
mcmurm
FYI I've had this same error once on an extremely cold morning and my truck only had around 10k miles on it at the time. I had other mornings equally as cold without any issues. Just wanted to throw that out there as parts of the country are experiencing cold weather.
Old Nov 21, 2022 | 04:08 PM
senix's Avatar
senix
this is why I always advise to run the def down the <200 to empty and then do a complete fill.
It helps to avoid the def tank sensor confusion.
Old Nov 22, 2022 | 05:16 AM
Gwilkrrs's Avatar
Gwilkrrs
yeah- i run it low prior to refill-
i think the time before the issue started it was so low it warned of limp mode in a certain number of miles due to being so low.
it is intermittent but has had me pull over to restart twice now due to miles and going into limp, so it is at the point of needing addressed.
need to figure my iphone and truck out with connecting to 4scan.
projectnitemare
6.7L Power Stroke Diesel
22
Oct 8, 2019 05:28 AM
Fefanatic
Jun 27, 2018 10:36 AM
Rubiconrod
Feb 12, 2017 07:21 PM
Walleye Hunter
17
Aug 20, 2014 06:14 AM
shenders99
Mar 9, 2007 08:12 PM
