back with my dying engine problem
truck starts fine. volt meter on dash reads over 12vdc at idle and right at 14 after 2000 rpm. brand new otima battery
drove today 5 miles surface road 35-45 without a/c then 10 miles on freeway 60-70 with a/c
entered chic-fil-a drive thru line (which was around the building so approx 10 minutes at idle with a/c and elec fan on
just as i start to pull away from window it stumbles and stalls... helpful chic guys/gals helped me push it to park space
tried to start..would turn over but not fire off... voltmeter reading less than 12 volts drops lower with starter engaged
let it set a few minutes tried again... it would try and start but stumble and die.. giving it gas did not rev engine
few minutes later tried again and started but running rough... till I could feather the gas pedal and get rpms up to 2000 it was rough running
finally smoothed out when alternator kicked in..
I looked in carb when it wouldn't start and opening throttle shows gas squirting as normal...so it ain't starving for gas...it's electrical.
I thought the new battery had fixed it but... evidently not. The battery is new . Alternator new. All the wiring is new and gauge is larger then
spec'd. all connections clean and tight. My head is sore from hitting the same wall...
more ideas please!!!
john
The battery supplies power to the starter to crank and it was cranking from what I just read.
The ALT only puts power back in the battery when running so not the ALT.
You did the first thing I would have checked, gas at the carb when throttle was moved and that was good.
So we have gas and air from cranking did we have spark?
You need to check for spark when this happens.
What are you running for IGN system?
Start from the key / wiring out to the dist., wires & plugs.
If you are running a DSII system I would say the IGN box is going bad.
If you get any replacement parts ask for the top of the line parts.
They are a little more money but if you dont ask for them they give you the cheap parts and they dont last.
As a side note you do have a thick gasket or a insulating plate under the carb right?
Dave ----
Why they painted them who knows as GM never did.
Dave ----
I too had fuel squirting into carb when the 33 stalled so I too was looking at electrical because I thought it's getting plenty of fuel.
Had a buddy explain to me that once vapor forms in the line it causes an airlock in the line which chokes off the vehicle due to starvation. Once the vehicle stalls the fuel pressure in the line refills the float bowl due to pressure so when you go to check the carb, gas will squirt as normal. I thought he was full of s**t, but turns out he was right.
I solved my vapor lock issue by doing the following:
1) Added a 1/2" fiber spacer for between the carb & Intake to insulate the carb from direct intake heat
2) Added 15 feet of DEI thermal tape for insulating the fuel lines by the engine, anything close to the heads, exhaust and I also insulated the electric fuel pump
3) Added a WIX 33040 vapor separator fuel filter with a return line (also insulated this filter with the thermal tape)
4) installed 25 ft of 1/4 vapor line so I could run the vapor line from the 1/4" fuel return nipple on WIX filter back to the 1/4" port I installed on my fuel tank.
What the WIX 33040 does is it provide an outlet for any vaporizing fuel and forces that back to the tank via the 1/4" vapor line verses causing an air lock and cutting off the fuel so the fuel can continue into the carb via the 3/8" nipple on the filter.
After installing all this I can run my 33 all day long on 100 degree weather sitting at idle or cruising without issues verses before I could go about 3 miles.
I also only now run 91 in all my classics because 87 or 89 with ethanol has a lower vapor point than higher octane fuel.
I also did the exact same thing to my 55 as preventative maintenance
Link to the filter I got on amazon -->
Jim
They used a Tee in the supply after the pump but before the carb with different orifice sizes depending how hot where you were.
This kept the fuel moving so it could not get hot.
AMC also used that filter on some of its cars (Gremlins & Hornets) and Jeeps.
It is not vapor but fuel that is moving in that line.
Now I got a question?
If the carb refilled because of pressure in the line pushing the fuel in, the motor should then restart no?
Why is it not restarting if you have gas squirting?
Dave ----
Dave ----
Jim
thought that cured it but Murphy was only jerking me around...
I only have that standard 1/8" spacer under carb...will remedy that tomorrow and today I ordered an undersized alternator pully... gonna try that before ordering a 140 amp unit
that is 200 bucks.
j
Jim
On v8 motors the carb sits right in the center of all that heat and heat rises and heats the carb.
This heat then boils the fuel in the bowl(s) and because the fuel is heavier than air goes to the floor of the intake manifold.
Now when you go and start it it just cranks till it clears out the fuel vapor just like if the motor was flooded.
I know when this will happen as I can smell gas fumes.
Some times this is worst with the brand gas you get and like most we get it from the same station.
Next time try a different brand of gas. If you normally use xxx brand next time get it from zzz brand to see what happens.
It has also been said to add a little diesel to the gas at fill up but I have not tried this as I dont really have this issue with my 300 six as the carb sits out to the side of the motor not over heat but I do get a little heat soak and I just hold the throttle wide open till it fires up.
that is 200 bucks.
j
The 1 wire senses out put at the out put stud and sees it is charging and kicks back the volts needed to charge the battery.
If you look how the ALT wiring was from the factory the sense wire was tied in to the main feed wire into the cab.
This was far enough away from the battery that the ALT would not charge with out over charging.
If you could run that sense wire even back to the battery post would be better than at the out put post on the ALT.
A higher out put 1 wire ALT is not the answer.
Dave ----
ps I dont know why some have issues and others do not?
Guess some get lucky
