the mounting bracket is the entire light bar....there are 2 holes over the license plate...it will bolt right up...need to buy the bolts for it....I hooked my lights up to the license plate light...the harness costs about 70 bucks at Ford..cheaper just to attach to existing wires..If I can figure out a way to post a picture i will try in the next day or 2...truck at body shop getting dent taken out of the roof...should have back tomorrow...
The four extra sockets are for the 4 marker lights on a dually. I removed the wiring harness and lights from my 350 SRW when I sold it. If anyone is interested in the wiring harness it will fit a 2001 built December or later in 2000. There was supposed to be a change made in the harness then but I have no idea what it was. Could have just been a part number change.
Greg
Alright, so this part number (F81Z-15444-AA) will get me everything that I need to put these lights on to the back side of my truck, right? If not, then what else do I need to order?
I just did this to my truck. Except, I went to AutoZone and the local boat shop (for the three lite bar which is the same as the one I have on my trailer which looks identical to the Ford one) and it was $12-16 dollars. It mounted using the factory holes too!!
Oh, the lite bars I saw came in black or just metal (galv?).
Did the $12 Autozone thing too. Piece came in black, fit fine, tied in thru OEM trailer wiring (brown wire) and used 2 sheet metal screws. About 15 minutes. Pic in my gallery:
Well I finally recieved my lite bar. I bought it online at www.buytruckstuff.com for $24.50 it is an LED type an came w/ harness. Part# TL-A-15050R. I tied it in to the license plate light.
Manny
Go to any place that sells trailer lights. You may even find these at Wally World. I believe they are made by Petersen Manufacturing, and they are 16" center for the holes. Just mount in the 2 holes in your box, tap into the license plate light wire and your good to go!
