Sponsored by: Real Truck
Squeaky Serpentine (Under Load)
Old Sep 14, 2022 | 10:52 AM
WWR's Avatar
WWR
Originally Posted by CharlieV5
WWR,
Just saw your recent msg. I just picked up a Harmonic Balancer from O'Reilly, and have an OEM brand HB puller coming from Amazon tomorrow. Not sure if the noise that I hear, even with the belt off, is coming from the HB or possibly something that the failed HB has damaged, or...... something that was damaged causing HB to fail. I just hope that this HB fixes the issue.
I wouldn't necessarily blindly replace it. You should be able to see if it's suspect. You should be able to observe wobbling as shown in the vid and I'd imagine the squeak is from physical contact with the motor so there should be witness marks
Old Sep 14, 2022 | 10:58 AM
WWR's Avatar
WWR
Aye, his video is quite bad but somewhere around 3:35 he seems to suggest the noise is from the balancer moving within itself. From what little I could see of his timing cover it didn't look scarred up, but between the poor vid quality and blathering about anything OTHER than the subject of the vid, I can't say conclusively
Old Sep 14, 2022 | 10:59 PM
CharlieV5's Avatar
CharlieV5
4wd Low
I just watched the video. I will try looking at my harmonic balancer tomorrow......maybe video it, and have my son on the gas pedal. Will let you know.
Old Sep 15, 2022 | 09:02 AM
Djosbun's Avatar
Djosbun
You probably have a vacuum leak where air is being sucked in through a seal when the engine is loaded. A smoke test might not locate the source but it’s worth trying. Could also have a vacuum line collapsing which causes a loud squeal. Saw this once when someone used a wiper washer hose in place of a vacuum line.
— Dave
Old Nov 4, 2022 | 06:04 PM
CharlieV5's Avatar
CharlieV5
4wd Low
2008 f250 5.4L Squeal Under Load
Well, Since I was out of options, I replaced the Harmonic Balancer.
No change whatsoever.
I took a 2 min video, this site says its too big, so I can't share it.
Looking back over the replies, Djosbun, you may have an idea there.
Old Nov 4, 2022 | 06:05 PM
CharlieV5's Avatar
CharlieV5
4wd Low
Do you have an email addr where I can send you this video?
Old Nov 5, 2022 | 08:53 AM
CharlieV5's Avatar
CharlieV5
4wd Low
Thanks for all your help. I was out of options, or so I thought, and went ahead
and replaced the Harmonic Balancer, no change whatsoever. I am going to
be checking for vacuum issues in a few hours.
Old Nov 5, 2022 | 10:05 AM
CharlieV5's Avatar
CharlieV5
4wd Low
240k Miles
DoubleOh7
Nov 23, 2016 02:18 PM
pm344
Mar 5, 2011 11:09 AM
StrokeThis96
Dec 30, 2008 03:19 AM
gdvizion79
1983 - 2012 Ranger & B-Series
13
Apr 18, 2007 01:15 AM
crash104936221
May 28, 2006 10:22 AM
