Engine block heater
Old Sep 10, 2022 | 01:16 PM
kyle20's Avatar
kyle20
4th Gear
Engine block heater
Since I haven't figured out how to search posts I will make one. I have a 2020 f150 with 3.5 ecoboost. I was thinking about adding a block heater but I can not find the correct part. Can someone tell the correct part for it. Some parts say it's for a 3.5 non turbo. Don't know what the difference would be between a turbo and non turbo when I thought they were all turbos. Also looking for a different brand then kats as it sounds like they aren't very good
Old Sep 10, 2022 | 03:01 PM
SpencerPJ's Avatar
SpencerPJ
You won't need one unless you get well below sub zero often. My 2020 doesn't miss a beat outside below zero. Keep a good battery in it.
Old Sep 10, 2022 | 03:44 PM
kyle20's Avatar
kyle20
4th Gear
I live in the north where it gets 30 below and sometimes colder and no they don't all come equipped from the factory. I don't have any problems starting. I just wanted less wear in those Temps. When they screech and groan in those temps
Old Sep 11, 2022 | 12:34 PM
GlueGuy's Avatar
GlueGuy
When I lived up in the great white north (north-central Minnesota), we all had tank heaters in our cars. Just plumb it into one of the heater hoses and it will keep the coolant at a warm temperature. Real simple, and I think it does a better job than a block heater.
Old Sep 11, 2022 | 07:15 PM
JKBrad's Avatar
JKBrad
I bought my truck brand new in San Antonio, TX and it had a block heater from the factory. It was a special order that someone passed on.
FoxxLandArc
Feb 25, 2015 08:07 AM
LIGOOMBA
Oct 5, 2010 03:28 AM
High Binder
Jan 13, 2010 06:17 PM
Big Ronda
Sep 15, 2009 04:54 AM
jmcgsd
Nov 9, 2004 06:31 PM
