Sponsored by: Halo Lifts
Engine block heater
Old 09-10-2022, 01:16 PM
kyle20's Avatar
kyle20
kyle20 is offline
2nd Gear
Engine block heater
Since I haven't figured out how to search posts I will make one. I have a 2020 f150 with 3.5 ecoboost. I was thinking about adding a block heater but I can not find the correct part. Can someone tell the correct part for it. Some parts say it's for a 3.5 non turbo. Don't know what the difference would be between a turbo and non turbo when I thought they were all turbos. Also looking for a different brand then kats as it sounds like they aren't very good
Old 09-10-2022, 03:01 PM
SpencerPJ's Avatar
SpencerPJ
SpencerPJ is online now
You won't need one unless you get well below sub zero often. My 2020 doesn't miss a beat outside below zero. Keep a good battery in it.
Old 09-10-2022, 03:44 PM
kyle20's Avatar
kyle20
kyle20 is offline
2nd Gear
I live in the north where it gets 30 below and sometimes colder and no they don't all come equipped from the factory. I don't have any problems starting. I just wanted less wear in those Temps. When they screech and groan in those temps
Old 09-11-2022, 12:34 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
When I lived up in the great white north (north-central Minnesota), we all had tank heaters in our cars. Just plumb it into one of the heater hoses and it will keep the coolant at a warm temperature. Real simple, and I think it does a better job than a block heater.
Old 09-11-2022, 07:15 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
I bought my truck brand new in San Antonio, TX and it had a block heater from the factory. It was a special order that someone passed on.
FoxxLandArc
02-25-2015 08:07 AM
LIGOOMBA
10-05-2010 03:28 AM
High Binder
01-13-2010 06:17 PM
Big Ronda
09-15-2009 04:54 AM
jmcgsd
11-09-2004 06:31 PM
Quick Reply: Engine block heater
