1995 F150
Old Sep 10, 2022 | 11:07 AM
Biggpapa1968's Avatar
Biggpapa1968
4wd Low
1995 F150
I just bought a 1995 Ford F-150. When taking a little drive in it, it overheated. When putting antifreeze in it, the coolant went from green to looking like water out of a mud puddle. There were no leaks or anything before overheating. So I am assuming that a full coolant system flush is warranted. I also assume that changing the thermostat needs to be done. My question is, after a flush of the radiator and coolant system, would I have to change the water pump?? I can change it myself, but really don't want to if I don't have to. Any advice is appreciated.
Old Sep 10, 2022 | 11:17 AM
Biggpapa1968
4wd Low
Ford F150
I should apologize. I should have introduced myself. I'm Greg, this is my first full size ford truck. I have very limited experience and ability for fixing or working on vehicles. I can do basic work. Thank you for any help and advice.
Old Sep 11, 2022 | 01:14 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Coolant turning into mud-puddle water usually indicates oil getting into the coolant then getting stirred up. This is probably going to be a head gasket issue but might be something else. I agree your best advice will come from the "1987 - 1996 F150 & Larger F-Series Trucks" forum.
Welcome aboard!
Biggpapa1968
New Member Introductions
Sep 11, 2022 01:14 AM
seadoo
Sep 27, 2009 06:02 PM
freirefishing
Jun 21, 2008 01:41 PM
