spedometer issue
Old Sep 9, 2022 | 10:47 PM
MiloClements's Avatar
MiloClements
5th Gear
spedometer issue
hey so on my 1992 f250 7.3 the speedometer doesn't work properly it goes back and forth about 20 mph difference constantly so I never know how fast I'm truly going. what is the most likely cause of this? and is it hard to fix? Thanks!
Old Sep 10, 2022 | 01:04 AM
Prototypemech's Avatar
Prototypemech
This is one of those problems where it's easier to throw a part at it than diagnose it.
on the rear axle housing, on top the center section, there's a black sensor with 1 harness connection and 1 10mm screw holding it on. That's the vehicle speed sensor. Replacement sensors are about $20, or cheaper if you get it from rock auto.
If you change that sensor out and you're still having problems, then you'll need to use a multimeter and find where the high resistance/problem is coming from.
Old Sep 10, 2022 | 06:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
as said, this is usually an issue with the VSS, or the speedometer head.
VSS is cheaper than a speedometer head.
Old Sep 10, 2022 | 02:39 PM
MiloClements
5th Gear
I just changed the vss sensor now the truck dosent shift
Old Sep 10, 2022 | 03:43 PM
Prototypemech
Post a photo of the vss you removed.
Old Sep 10, 2022 | 04:06 PM
tjc transport
i ain't rite
motorcraft part or aftermarket? when i comes to sensors for fords, i always use motorcraft.
Old Sep 10, 2022 | 04:13 PM
MiloClements
5th Gear
It was aftermarket not motorcraft
TallinFord
Apr 5, 2019 08:10 AM
cali_7.3
Aug 27, 2015 09:53 PM
Slackeyed
1997 - 2003 F150
23
Jan 7, 2006 08:36 AM
loadera10
Dec 11, 2005 09:35 PM
